still having brake problems.....help!
  • Thread starter Thread starter jmd2914
  • Start date Start date Sep 21, 2005
J
jmd2914
937
Napa, California
Sep 21, 2005
  • Sep 21, 2005
ok guys, first off i want to aplogize for posting so many times about my brakes but i still cant get it right. heres whats goin on, ever since i swapped the pads about half the way around the rotor ( durring one full rotation of the wheel) on the front drivers side, the pad and rotor are touching which i dont think should be happening. and when i turn the steering wheel either way it sounds like the brakes are rubbing, and im not sure what to do. now with the back brakes, im tryin to get the pins out and theyre rounded off, anyone have any ideas on how to get them out? i would really appreciate it, if someone could walk me through the rear brake pad install i would appreciate it. sorry for the noob post guys but im tryin to do this right not just get it done.
J
jmd2914
937
Napa, California
Sep 21, 2005
  • Sep 21, 2005
bump....anyone?
HISSIN50
34
129
Sep 21, 2005
  • Sep 21, 2005
I dont get it, but will try.
on the front, are the rotors new? Are the lines completely bled? Air in the system can keep the piston in the caliper from retracting as far as it should. Warped rotors can allow enough run-out that the pad drags.
A dirty, bent, etc slide pin can keep the caliper from floating as it should.
On the rears, what pins do you mean? Do you have disks back there (you mentioned rear pads and not shoes). My first thought related to drums and the pins which have to be turned 90* to release...... but I dont know what kind of brakes you have.
Good luck.
J
jmd2914
937
Napa, California
Sep 22, 2005
  • Sep 22, 2005
ok, some progress was made, i got the old pin out ( i have 4 wheel disk brakes from a lincon mark 7 by the way) but now i cant get the back pad off. anyone have any idea how?
P
plainwrecknate
92
Fort Morgan, CO
Sep 22, 2005
  • Sep 22, 2005
you can't get the pad off the caliper or you can't get the caliper off the rotor? when i changed my front pads, the driver's side was real snug and i had to tap the caliper with a rubber mallet slightly to get it off the rotor. the pads should just pop/slide off.
J
jmd2914
937
Napa, California
Sep 22, 2005
  • Sep 22, 2005
i got the new pads on, the problem is when i got the caliper back on the rotor, the pads were rubbing against the rotor.
HISSIN50
34
129
Sep 22, 2005
  • Sep 22, 2005
Are your caliper pistons moving freely and free of crud under the dust boot? Could the caliper be binding?
And are the slide pins free of crud?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Sep 22, 2005
  • Sep 22, 2005
The rear disc brakes that also act as the E-brake the piston must be turned as it is pressed inwards. There is a professional tool for this but there is also a tool that looks like a cube with little prongs on the edges, that works also. The prongs go into two of the four slots in the piston. Once pressed back there should be a slot at the 12, 3, 6, and 9 o'clock postion holding the caliper level. Prongs on the brake pad should go into these slots when the caliper piston moves out. On the front, sounds like warped rotors.
J
JRitt@StopTech
  • Sep 22, 2005
New StopTech Tech Articles on Brakes
Hi Everyone,
Each day on the automotive message forums such as this one, StopTech sees the same brake-related questions asked over and over again. We wanted to let you know that we’ve been busy addressing these issues via technical articles on our newly redesigned website…’warped rotors,’ noisy brakes, how to bed-in pads and rotors, how to bleed brakes, what type of brake fluid to use, prepping your car for the track, etc. Please find the answers that you’re looking for in our most recent ‘Whitepapers’:
http://www.stoptech.com/tech_info/tech_white_papers.shtml
We think that these articles will save many of the forum veterans a lot of time and frustration in dealing with repetitive questions…enjoy!
Jeff Ritter
Sales Manager the Americas
StopTech, LLC
jeff@stoptech.com
310-325-4799 x104
J
jmd2914
937
Napa, California
Sep 22, 2005
#10
  • Sep 22, 2005
  • #10
i didnt take the dust boot off the piston, should i have? and all the pins have on them is the grease that was on there from when the came out that im assuming is supposed to be on there.
HISSIN50
34
129
Sep 22, 2005
#11
  • Sep 22, 2005
  • #11
I sometimes do just to get all the built up crap out of there - it is not necessary.
The slide pins often have a sacrificial coating which wears off - renewing the pins is the best solution (if the caliper wont slide on the pins easily).
Mr. Ritter, as I am sure you know, I think you might need to contact Admin before posting brand-specif info and representing your company (if not mandatory, it might be a nice courtesy. We want you to hang around here. ). I might be thinking of another forum where one has to do this.....
I read a little of your FAQ and noted the 'warpage myth' info. I probably missed it, but does the part about the author not having seen a rotor warp (I think he said that), but rather have excessive build up of pad material on the rotor, include cheaper parts store rotors? I would expect a great product like you sell to not warp if proper procedures are followed, but still kinda' wonder about perhaps inferior products.
J
jmd2914
937
Napa, California
Sep 22, 2005
#12
  • Sep 22, 2005
  • #12
alright, update time. i got all my pads swapped finally, put new pins in the back where needed. i got everything on and it looked like it fits well, but the pads are rubbing on the rotors. is this normal until they wear in or no?
HISSIN50
34
129
Sep 23, 2005
#13
  • Sep 23, 2005
  • #13
Do the pads just touch the rotors or is there any actual dragging (where it slows the rotor down as it spins)?
Older caliper pistons often dont retract real great, so once the hydraulic pressure is released, the piston goes back a bit - often from the rotor pushing back against the pads. But it does not want to go back further. Air in the system can also create retraction issues (mentioned as an aside).
Good luck.
J
jmd2914
937
Napa, California
Sep 23, 2005
#14
  • Sep 23, 2005
  • #14
thanks, there is some dragging on the front left rotor but not much, not enough to notice while driving but if i jack up the car and spin the tire i can hear it dragging about half way around.
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
