Still Overheating, DESPARATE!
  • Thread starter Thread starter fox racer
  • Start date Start date Aug 11, 2006
fox racer
577
Staten Island, NYC
Aug 11, 2006
  • Aug 11, 2006
Well after a short leave of absence, im back. my comp is broken so im using my dad's lap top till I buy one. As some of you kno, im having an overheatin problem, and well Im not only stumped but Im FED UP. Heres a list of whats been replaced:
Heads (GT40 Y303 aluminum)
Intake (Cobra)
ALL the Gaskets
Coolant
Water Pump (Summit peice, flows 30% more)
Thermostat (180* Mr. Gasket Fail proof)
Stock Fan is FINE
Fluidyne Radiator
I was planing on re installing the stock pullies since Im trying to Save money. I was going to get a Black Magic Extreme fan but I would REALLY like he avoid that since I still need a lapttop for school and I would have REALLY liked to get an Ipod for the gym/school/work commute.
The problem Im having is it will go up tp like 220 or higher at idle, then only cool off when i start to drive. even then it sits at like 195-205 maybe higher depending on how hot it is out. Im not losing and oil (except for some minor burnoff which my car has always done, maybe about .5 qt every 2 months), collant level is going unchanged, and I dont smell anything. All this crap started happening once the weather started to get warm and after i replaced the motor mounts and added long tube headers. I kno my motor doesnt sit perfectly straight (tilted slightly)from the motor mounts, coul this affect it that much? I have checked and rechecked for any bubbles. Headgasket maybe? running Lean possibly?
PLEASE help, I just want my car to be reliable, I dont wann stress out over traffic anymore lol.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Aug 11, 2006
  • Aug 11, 2006
Are you SURE your fan is fine? From the sounds of it it doesn't sound like it. If you have a thick aluminum radiator, that pushes the rad out towards the engine farther, which makes the fan sit closer to the rad itself, making it much less efficient. If it's overheating at idle, but not at speed.. then this is an easy answer and fix. You dont have enough airflow over the rad. at idle when the car isn't moving. You need to get a new fan clutch (Police HD fan clutch is your best bet FROM FORD), or go for the electric fan/DC Controller setup. www.dccontrol.com has Mark fan+controller setups for around 320 bucks. Money well spent, and as long as you have a 3G alt, you will be cool as ever.
Nick
HISSIN50
34
129
Aug 11, 2006
  • Aug 11, 2006
It seems like a few issues could be there. It sounds like you have U/D's - that doesnt help anything and can make fan diagnostics hard. The fact that you run a bit hot at speed (assuming the air dam is present), coupled with the hot stationary running, sounds like a heat rejection issue. I see your nice Fluidyne radiator though. Are you sure you trust the gauge you're using?
Is the cooling system holding pressure?
I'd get stockish pulleys back on first. Then evaluate the idle temps. You can do a J/Y fan and alt upgrade if you need to.
Good luck.
pb_paulie_b
894
Chaptico, Maryland
Aug 11, 2006
  • Aug 11, 2006
In cases like this it could be something not very obvious. Underdrives, stuck stat, wrong placement of the intake gaskets, are you running the back plate for your water pump?
DJTR
228
OTTAWA, Ontario, Canada
Aug 13, 2006
  • Aug 13, 2006
if you don't drive it in the winter take out the thermostat and see that that changes anything. If the thermostat is sticking that could be causing alot of your issues.
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
D
03 mustang Mach 1, 4.6L None Supercharge
  • DangStitches
  • May 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 23, 2025
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Electrical Inaccessible starter solenoid from wire tuck, what are my options for an alternator upgrade?
  • AnthonyA1234
  • Jan 16, 2025
Fox 5.0 Mustang Tech Feb 8, 2025
Mindseye007
