Stock 302
  • Thread starter Thread starter joeswann38
  • Start date Start date Dec 4, 2009
J
joeswann38
  • Dec 4, 2009
I have just recently joined stangnet and dont know how to post on the forums yet but i have a question. I recently ran aross a 302 out of a 83 F-100 2wd it is a very strong motor with plenty of torque but i want to know what the biggest cam that i can put into a 302 is without having to get a stall converter or change the heads...
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,117
224
Massachusetts
Dec 4, 2009
  • Dec 4, 2009
Need way more info to answer that question correctly.
M
mikepotts
81
  • Dec 4, 2009
x's 2 if you want an accurate answer, be VERY specific. if you want something that sounds good for cruising or whatever, say so. dont blow smoke, just tell us like it is...
J
joeswann38
  • Dec 4, 2009
Ok sorry guys..I just want to make it sound good
M
mikepotts
81
  • Dec 4, 2009
WOW! honesty... nice, well... i imagine you dont want to put a bunch of money into it, with that in mind i think i would get a summit cam kit, maybe the SUM-K3600 it is a hydraulic flat tappet cam and lifter set, with enough duration to give a nice sound, a split lift pattern to help the exhaust (typically weak on SBF's) and should make power in the lower RPM's plus you shouldnt need to upgrade springs (if yours are not wore out). i think it is like $89.00 plus gaskets.
J
joeswann38
  • Dec 4, 2009
Thanks man.. I have been trying to get that answer for about a month and everyone said it couldnt be done without changing everything...THANK YOU
M
mikepotts
81
  • Dec 4, 2009
no problem man, this cam is small, and should work with all stock stuff including 2bbl carb.(if you still have one on it).
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
T
New Guy from Southeast Missouri
  • tcooke11
  • Jan 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 17, 2026
TomcatPC
