LilBerx Active Member Jan 11, 2012 340 26 29 Logan, UT Dec 19, 2012 #1 Dec 19, 2012 #1 Well I have a few questions about Cams. My 88 GT is really loapy. Was there different cams made for 5.0 foxbody platforms? I read somewhere that 88 had the most aggressive cam? I just need someone to chime in.
NIKwoaC 中國製造 15 Year Member Oct 31, 2006 5,525 943 214 Chengdu Province Dec 19, 2012 #2 Dec 19, 2012 #2 The below is a post made by Bullitt95 made on another site. The stock cam is really tame and shouldn't really be causing any lope. Stock GT cam up to 8/10/88: Advertised duration 266/266 0.050" lift duration 210/210 Lobe lift 0.278"/0.278" Valve lift 0.444"/0.444" LSA 115* ICA 116* ECA 114* Stock GT cam after 8/10/88: Advertised duration 276/266 0.050" lift duration 214/210 Lobe lift 0.278"/0.278" Valve lift 0.445"/0.445" LSA 115.5* ICA 118* ECA 113*
VibrantRedGT "STANGNET'S PENGUIN SMACKER" 15 Year Member Nov 29, 1999 14,679 424 154 Boca Raton, Florida Dec 19, 2012 #3 Dec 19, 2012 #3 Nothing aggressive about either of those stock cam specs.
ratio411 Founding Member Apr 21, 2002 3,870 73 109 Pensacola FL Dec 19, 2012 #4 Dec 19, 2012 #4 NIKwoaC said: Stock GT cam up to 8/10/88: Advertised duration 266/266 0.050" lift duration 210/210 Lobe lift 0.278"/0.278" Valve lift 0.444"/0.444" LSA 115* ICA 116* ECA 114* Stock GT cam after 8/10/88: Advertised duration 276/266 0.050" lift duration 214/210 Lobe lift 0.278"/0.278" Valve lift 0.445"/0.445" LSA 115.5* ICA 118* ECA 113* Click to expand... Well, since August is the start of the next year model, you might as well say that 85-88 models have the first cam, and 89-95 models use the 2nd cam. I have always heard that 85-86 engines have a separate cam spec too... but I don't know that for sure. As other stock cams go, those are some pretty racey specs... However, I wouldn't expect to hear much lope out of it with such high LSAs.
Dino Dino Bambino 15 Year Member Jun 13, 2007 1,672 89 79 Cyprus Dec 20, 2012 #5 Dec 20, 2012 #5 ratio411 said: As other stock cams go, those are some pretty racey specs... However, I wouldn't expect to hear much lope out of it with such high LSAs. Click to expand... The stock GT cam is tame and there's no lope. Opening duration is pretty modest and with the wide LSA, there's not much valve overlap.
ratio411 Founding Member Apr 21, 2002 3,870 73 109 Pensacola FL Dec 20, 2012 #6 Dec 20, 2012 #6 Bullitt95 said: The stock GT cam is tame and there's no lope. Opening duration is pretty modest and with the wide LSA, there's not much valve overlap. Click to expand... Yep. I was just saying that compared to other stock cams, it is pretty stout.
Dino Dino Bambino 15 Year Member Jun 13, 2007 1,672 89 79 Cyprus Dec 20, 2012 #7 Dec 20, 2012 #7 ratio411 said: Yep. I was just saying that compared to other stock cams, it is pretty stout. Click to expand... Indeed it is.
