stock 5.0 what cam
  • Thread starter Thread starter sandbum
  • Start date Start date Jan 5, 2008
sandbum
utah
Jan 5, 2008
  • Jan 5, 2008
i know i have searched and still dont have an answer i need a cam that will work well in a stock engine with a 150 shot by the way the engine is in a long travel sand rail with a 5.13 ring & pinion its also carbed with vic. jr intake other than that stock as a rock.
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
West Coast Best Coast
Jan 5, 2008
  • Jan 5, 2008
I would concentrate on a set of heads first. They are a bottle neck. The stock cam is pretty good. Probably the best application with stock heads.
sandbum
utah
Jan 5, 2008
  • Jan 5, 2008
thanks what heads would you recomend i had a set of vic jr. on my 347 what do you think of the world products iron heads.
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
Jan 5, 2008
  • Jan 5, 2008
Not sure. Hopefully someone will come in who knows about them. But I would assume they are far better then the stock e-7's. How much are they?
Depending on how much you wanna spend will give a better understanding on where to go. Ideally Head's and a cam would wake it up. But again, how much cash do you have to spend?
bloopbloob
578
Alberta
Jan 5, 2008
  • Jan 5, 2008
+1 on the stock cam being good for an only mild mod 5.0. i've heard this time and time again from the pro's. unless you're doing a head swap or some other major mods, the stock cam is pretty good. i've also seen a couple recent posts on the worlds, people seem pretty pleased with the performance for the price. do a search on here and i'm sure you can find what you need about everything.
Fast63
717
  • Jan 5, 2008
add another vote for the stock cam. I have the world products Roush 180 heads and I am not impressed. When I bought them new, they were $720 on a discount, and twisted wedge heads were about $950. Now you are talking about 1k for the world heads and 1100 for twisted wedge. Take it from me, you're going to like the twisted wedge heads much better, or any other aluminum head for that matter, minus the ford racing heads.
Though they are a great improvement over stock, I think the flow is still not as good as other heads. When I got mine there were metal shavings around the valves and seats, the holes for the accessories were drilled slightly off where they should be, the guideplates that came with the heads were complete garbage and broke after 200 miles, and you can't use 1.7 rockers with them if you decide you want some later. If you want them for smog, you have to drill them yourself... Just save the headaches IMO
NKau
1,346
Jefferson, WI
Jan 6, 2008
  • Jan 6, 2008
Another vote for the stock cam.
foxmustangman
196
Idaho
Jan 6, 2008
  • Jan 6, 2008
What are some good heads? GT40, Edelbrock, or what?
M
Matts89LX5.0
1,314
Long Island, NY
Jan 6, 2008
  • Jan 6, 2008
stock cam will be fine unless you are upgrading the heads.
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
Jan 6, 2008
#10
  • Jan 6, 2008
  • #10
GT40's, If you have the money AFR's are a 100HP bolt on.
PUNISHER RACING
1,124
FORD CITY, PA.
Jan 7, 2008
#11
  • Jan 7, 2008
  • #11
I vote for an X cam and AFR 165's with that intake
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Engine 1990 5.0 bogs and pops over half throttle
  • Sander
  • Aug 1, 2025
Fox 5.0 Mustang Tech Aug 2, 2025
AeroCoupe
