  • 1994 - 1995 Specific Tech
Stock AODE Q
  • Thread starter Thread starter final5-0
  • Start date Start date Jun 12, 2005
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 12, 2005
  • Jun 12, 2005
Yall can laugh if you want to but ...... I've never really spent any time to learn about the auto trans in our Stangs
Like Luke, I ain't gonna go over to the Dark Side
However, I've been wondering about this Q for some time now
On a stocker, does it totally lock up or does it slip a bit in overdrive?
If it does slip, how do you stop that chit if you wanna push a good bit more hp to it?
Later
Grady
bjl95mustang
1,495
Austin,TX
Jun 12, 2005
  • Jun 12, 2005
www.tccoa.com tech then tranny.
The converter should slip but not the od band. When the band slips it creates heat and thats bad for it. The way to prevent it from sliping is to use a overdrive piston with a longer rod and it will put more force on the band and prevent it from slipping. There is better info and pics on what i'm talking about on the site I listed.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 12, 2005
  • Jun 12, 2005
Thanks a lot!
I go over there and check things out.
Later
Grady
HISSIN50
34
129
Jun 12, 2005
  • Jun 12, 2005
The TCCoA site that BJL linked to is a really sweet place - I go there for trans info. (and anything written by Jerry is golden, as far as I am concerned).
Guys have rigged up switches to control lock-up manually too (something to keep an eye out for perhaps).
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 12, 2005
  • Jun 12, 2005
Lots of good info over there for sure.
I went over there and skimmed through a good bit of that stuff with a focus on the basics.
Looked like to me that 3rd & 4th locked up.
That makes me wanna ask another Q.
You know how an auto will put up smaller dyno numbers?
If their 3rd ratio is 1.00 and it is locked......why the smaller dyno numbers?
Later
Grady
bjl95mustang
1,495
Austin,TX
Jun 13, 2005
  • Jun 13, 2005
The converter is not totally locked up. You have to get a multi disc converter to get a total lockup. The single disc converters clutches cant hold the converter to a 1-1 with out slipping. I have played with my tweecer and tried a 1-1 lockup and it would slip when i punched it till it caught then it held decent. If I had a multi disc it wouldent have slipped when i punched it.
Brandon
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 13, 2005
  • Jun 13, 2005
Brandon
Brandon
Thanks so much for the info.
I've always been curious about that kind of basic stuff when I look at combos who run the aode.
Later
Grady
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jun 13, 2005
  • Jun 13, 2005
Im not too sure what youre asking, but on my PI STallion, I was told that it will lock up, but only at certain times.. Unfortunately, It's been in over 2 years, and I dont remember exactly what the explanation was.
RC
D
DavidNC
119
  • Jun 13, 2005
The aode is a computer controlled tranny, and the converter lockup's can be reprogrammed. So can line pressures and shift points.
I want to reprogram my 95 aode for performance. After research the options, I decided to go with TwEECer.
I also started a GP ($505ea TwEECer RT shipped) on the Corral for to help get the price down:
http://www.corral.net/forums/showthread.php?p=4872330#post4872330
Only one more buyer needed.
David
bjl95mustang
1,495
Austin,TX
Jun 13, 2005
#10
  • Jun 13, 2005
  • #10
Right, what i'm saying is the converter will lockup but still slip. The computer will lock the converter but it's still not a 1-1. The stock and single disc converters cant handle the stress with only 1 internal disc. I'm having to mail mine back to pi to get it upgraded to a multi disc setup then i will beable to lock it 1-1 with my 418. The single disc converters will still take 1000+ hp but you wont beable to lock it to a 1-1. I want to beable to lock it in all gears so i'm upgrading mine.
I have a few of jerrys ecc tunes for a aode/4r70w and it's alot different than the stock tune with line presures ect.
SuperDust22
The Power of Pixie Dust?!
Oct 19, 2003
1,821
Gilbert,AZ
Jun 13, 2005
#11
  • Jun 13, 2005
  • #11
I was about to ask what you used to tune you AODE? I have never heard of Jerry's ecc tuner. What is that? I have wanted to but something for my AODE to control line pressure, etc but that are all around $500. I was hoping to find one cheaper.
Dustin
SilverFoxbody
149
#12
  • Jun 13, 2005
  • #12
If you guys have questions about trannies, I can help. I try to only hang with AOD/E/4R70W questions on these boards.....
3rd is 1:1 kinda, not becuase the clutch slips in the converter, but direct clutch instead. If the converter clutch starts slipping, you get chatter or shudder.
The TC has a clutch in it just like a any clutch, that is held by fluid pressure. The TC lock up schedual can be altered by program. It can somtimes almost feel like a 4th gear before shifting into 4th. You will notice under throttle, the TCC is not locked up, but let of the throttle, the TCC locks and you get a small thud and drop in RPM. On the big big brother tranny AOD there is no variable lockup, only full all the time in 3rd and 4th.
If the OD band slips you will notice it slipping as you have no accerlation in 4th.
bjl95mustang
1,495
Austin,TX
Jun 13, 2005
#13
  • Jun 13, 2005
  • #13
I use a tweecer and i have a few of jerys tunes.
bjl95mustang
1,495
Austin,TX
Jun 13, 2005
#14
  • Jun 13, 2005
  • #14
Whhen I was talking about a 1-1 i ment 100% lockup. I know the stock program runs a 80-90% lockup so it slips the converter about 10-20%. I'm no expert on the aode and if this is wrong lmk.
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
D
supercharging my v6 4.0
  • dreamerv6stang
  • Jan 12, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 21, 2025
tovlux6
T
Help with AFR reading
  • dz01
  • Nov 14, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jan 8, 2025
GOvert
G
J
  • JRC99
  • Apr 19, 2025
JRC99
J
