  • SN95 4.6L Mustang Tech
Stock Block
  • Thread starter Thread starter laxdman20
  • Start date Start date Feb 16, 2006
1 of 2 Next Last
laxdman20
95
Va.
Feb 16, 2006
  • Feb 16, 2006
I just installed a vortech V-2 sq with anderson power pipe. I droped it off at the tuners and he told me that I was probably looking at around 370-375rwhp. Well I just got a call yesterday saying that its making 408 rwhp and 415 ft. lbs. of torque. But at 4700 rpms my 38 # hr. injectors (the ones from vortech) are at 100% duty cycle, so he wants to throw 60 #hr's in there because of the power I want to make down the road. What I really want to know is how much power can I get out of this stock block and stock internals before I have to start worrying?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Feb 16, 2006
  • Feb 16, 2006
hey , where you at in Va , dont know about all that , the 38s should be good to close to 450rwhp or more , I have seen cars with blowers and 30 lbs injectors go 380rwhp before before they were maxed out so I dont see how they are maxed out that soon .....if anything just step up to 42 they will definitely be enough , oh and to answer the question 400-420 is about the limit on stock internals ....
K
Kuestone
93
California
Feb 16, 2006
  • Feb 16, 2006
Step up to 42 lb injectors and get a richer tune to lower power to about 400 thats pretty much max safe hp on stock block well you could go a lil more no more then 430 but more then 400 and id worry everytime i punch it.
laxdman20
95
Va.
Feb 16, 2006
  • Feb 16, 2006
Im up in alexandria. And the car is down at Excessive Motorsports in Manassas.
back_in_black
460
frederick, MD
Feb 16, 2006
  • Feb 16, 2006
I would go up to the 60's, I did, and yes over 400 and you are pushing it !
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Feb 16, 2006
  • Feb 16, 2006
yeah 400 is the max even on a good tune at that power level is pushing it, all it takes is for something to go wrong and there goes your stock block. So i would start to save up for froged internals or forged short block
reddrgn01gt
161
Pittsburgh, PA
Feb 16, 2006
  • Feb 16, 2006
You really don't want to go over 80% duty cycle with injectors. If you plan on making more power in the future get the 60s. You can always tune for less fuel but you can't for more. Just my .02.
laxdman20
95
Va.
Feb 16, 2006
  • Feb 16, 2006
Well does anybody know a good brand of forged internals, cause it sounds like im gonna need them fairly soon.
sgarlic
3,085
Feb 16, 2006
  • Feb 16, 2006
There isn't a max HP the block can handle. It depends on the tune. As you have probably read, there are people making nearly 500 on the stock block with great tunes. There are also those who've blown up the stocker running less than 400 with crappy tunes, bouncing the rev limiter, etc. You're on borrowed time running a supercharger or turbocharger on stock internals period.. whether it's 6psi, 9psi, 14psi, etc.. just don't kid yourself and think just because you're around 400 that you're safe. Every blown application should realize this, and have a plan to forge down the road.
Bottom line, don't be surprised or dissapointed if you blow the stock engine up.. they aren't made for the kind of power most of us desire.
03GTconv
49
Fort Worth
Feb 16, 2006
#10
  • Feb 16, 2006
  • #10
Yeah get on ebay and look for the seller SPEEDYPARTS, he has every forged internal setup for your 4.6, i suggest goin with his 4.6 281ci conversion to 302ci forged.
03GTconv
49
Fort Worth
Feb 16, 2006
#11
  • Feb 16, 2006
  • #11
Yeah go to ebay and look up the seller speedyparts, he has every forged application for your 4.6 and 5.0. I suggest goin with the 4.6 281ci conversion to a 302ci, itll run u around 1900.00 if u wanna go cheaper u can get a forged setup for around 1000.00
2003 Mustang GT Prem Conv.
Charcoal Grey
246.5 RWHP 289.3 RWTQ
MAC CAI
bbk 75mm TB
C&L Plenum w/spacer
C&L 85mm Maf
SLP Loudmouth C/B
Diablo Predator
Eibach Sport Springs
2001 Cobra Front Bumper
Mach1 Chin spoiler
2004 Cobra Rear Bumber
Just added and Not Dynoed
BBK Ceramic LongTubes
BBk O/R H-Pipe
mineralgray2002
33
Centralia, Illinois
Feb 16, 2006
#12
  • Feb 16, 2006
  • #12
Can you keep the stock block if you get forged internals? or do you need to get a new block with it? im new to the forced induction stuff and im looking at getting a blower really soon i just need to find out what else ill need to make it work fine without a worry of blowing it up
ADRENLN
2,342
NJ
Feb 16, 2006
#13
  • Feb 16, 2006
  • #13
your actual block is fine, you just have to forge the internals. some just buy a whole built block cause it is put together professionally which is what i plan to do
mineralgray2002
33
Centralia, Illinois
Feb 16, 2006
#14
  • Feb 16, 2006
  • #14
which vortech blower whines the most? ive been looking at a kenne bell 1.7 because they are supposed to be like the best, but prices are to high so now i want the obnoxious whining sound from under the hood but still enough power to make it worth the money, im tryin to keep it with stock internals until i can get the money for the forged shortblock. What all rearend parts will have to be upgraded?
laxdman20
95
Va.
Feb 19, 2006
#15
  • Feb 19, 2006
  • #15
mineralgray2002 said:
which vortech blower whines the most? What all rearend parts will have to be upgraded?
I dont know which one whines the most, but the V-1 has a pretty loud whine to it. Espically at idle. For the read end, you should upgrade your gears to some 373's or some 410's depending on what you want. I have 373's and love them. You can get away with not upgrading your axles as long as you arent going to be using any type of slicks, but I would plan on upgrading the axles anyway.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 19, 2006
#16
  • Feb 19, 2006
  • #16
get the 60's 100 percent duty cycle is BAD. you don't want to end up running lean.
BTW those good to X horsepower things like this injector is good till 400. that stuff is just a guide. some setups will need a bigger injector at a lower power level.
sil_stang02
39
Northern Virginia
Feb 19, 2006
#17
  • Feb 19, 2006
  • #17
Hey man, I live here in fredericksburg va, how much did the shop charge you for the installation and tune?
laxdman20
95
Va.
Feb 19, 2006
#18
  • Feb 19, 2006
  • #18
Well the chip, programing it and the dyno pulls came out to around $600. But we decided to try the 42 # hr injectors and they worked just fine. It came out to $1052. I dont know what my numbers are yet. Excessive called up my buddy at work to tell him the numbers and how much the bill was (casue he knows all the guys down there) and he looked at me and said, "Your bill was $1052 but I'm not gonna tell you what your numbers were, you'll have to see it to believe it." I'll post them when I get them... The suspence is killing me.
laxdman20
95
Va.
Feb 20, 2006
#19
  • Feb 20, 2006
  • #19
Numbers are in. 413 rwhp and 413 ft lbs of torque.
W
Will Smith
191
Cape Coral, FL
Feb 20, 2006
#20
  • Feb 20, 2006
  • #20
man that place is the pits. good clean shop but the prices there are outragious. They wanted to charge me 500 bucks to install some 3.73's and i alreayd had everything needed for it.
1 of 2 Next Last
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
D
supercharging my v6 4.0
  • dreamerv6stang
  • Jan 12, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 21, 2025
tovlux6
T
