S slow88LX New Member Apr 4, 2005 25 0 0 Jun 8, 2005 #1 Jun 8, 2005 #1 stock fan removal...i'm stuck help! how do i remove the stock fan? which bolts do i take out? if it is the bolts that are on the outside of the pulley, then how do i hold it still? thanks -Travis
04sleeper Founding Member Jun 22, 2002 2,674 14 89 Dallas, TX Jun 8, 2005 #2 Jun 8, 2005 #2 Loosen the bolts with the belt still on and it won't slip. Then take the belt off.
PuterAmI Member Mar 29, 2003 513 0 16 Madison, Alabama Jun 8, 2005 #3 Jun 8, 2005 #3 You hold it still with the belt on. Or a long, thick screwdriver against a bolt and the center shaft. Although the last one cannot be loosened this way.
Mustang Yawie Founding Member Jul 21, 2002 281 14 28 Rialto CA Jun 8, 2005 #4 Jun 8, 2005 #4 also remove the two fan shroud bolts and remove the overflow tank hose to the radiator when pulling the hole thing out
89MustangGX I have nothing productive to add! Jul 3, 2001 10,262 1 0 Mill Creek, WA Jun 8, 2005 #5 Jun 8, 2005 #5 They lick to "stick" on there a little, so don't be surprised if it doesn't exactly fall off when the last bolt comes out.
