Stock fuel rails not enough? Recommendations on new ones?
  • Thread starter Thread starter thompsonsd
  • Start date Start date Mar 11, 2004
T
thompsonsd
144
Southern Maryland
Mar 11, 2004
  • Mar 11, 2004
Anybody know if my stock fuel rails are handling my mods ok, or if an aftermaket set would make a difference? My sig. has my major mods. Any suggestions on which rails would be best or where to get them?
Thanks!
J
Jesseswhite87GT
118
Springfield, MA
Mar 11, 2004
  • Mar 11, 2004
Thanks!
U should be fine. I've herd that stock rails are good up to 450-500 horse. Plus I've heard installing aftermarket rails is a Bit ch beacuase of clearance problems with the intake.
T
thompsonsd
144
Southern Maryland
Mar 11, 2004
  • Mar 11, 2004
It'd be cool if I don't have to change them. Since I have the GT-40 intake with a 3/8 spacer I don't think I'd have any clearance problems though.
J
jjd975
4,236
louisville,kentucky
Mar 11, 2004
  • Mar 11, 2004
Stock fuel rails can handle closer to 600 hp. Your fine.
flyinghi3
313
Manorville, LI
Mar 11, 2004
  • Mar 11, 2004
what alot of people are doing around by me is installing 94-95 stock fuel rail. they are bigger then the 87-93 rail. you can pick up a used set for around $75-$100 with a adjustable fpr. i just got mine used with a adjustable fpr for $95. they are almost a direct fit, you just have to bend one of the supply line i little. from what i heard the stock fuel rails are good up to about 450hp.
T
thompsonsd
144
Southern Maryland
Mar 11, 2004
  • Mar 11, 2004
I should probably give the reason I asked this. When I had my old pump I had a severe pressure drop when I hit the throttle, back when I had 24# injectors. Then I upgraded to the 255lph BBK pump and FMS 30# injectors, also new fuel filter. Now when I hit the gas I still see a pressure drop, not huge, but very irritating... Is this normal, I thought that will a 255lph pump there wouldn't be a drop??
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
Fuel rail help
  • stang9150
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2026
stang9150
N
89 LX 5.0 Fuel Rail Recommendations
  • Ncarter
  • Oct 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 18, 2025
rednotch
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
