By adding a spacer you are lengthening the runners which will make it even worse. Just remember, a general rule of thumb is that the shorter the runner length, the higher up in the rpm range the intake will make power. The only way to fix it is to shorten the runner length (you may be able to mill a little of the upper and lower intake were they meet) or swap it for somehting better like an edelbrock.
