Are the stock 88-93 MAMs not 55mm? Does anyone know what the CFM is that they flow stock? Or is it really 606 CFM and the 58mm diameter listed is a misprint? How about a bored out to 60mm stock MAF? How many CFM would that flow?
Cause See....
I checked the 94/95 FAQ with the all the airflow #s says:
MAF AIR FLOW DATA (In CFM):
1.Stock 5.0L 58MM (89-93 Mustangs), 606 CFM
2.Stock 5.0L 70MM (94-95 GT/Cobra Mustangs), 815 CFM
3.Pro-M Bullet (75MM), 964 CFM
4.Ford 80MM (Lightnings), 1017 CFM
5.C&L 73MM, 1171 CFM
6.Modified 80MM (Flow Bar Removed), 1368 CFM
7.C&L 80MM, 1415 CFM
8.Pro-M 77MM (Shorty/Supercharged Version), 1543 CFM
9.Pro-M 77MM (Standard Version), 1562 CFM
10.Pro-M 83MM, 1598 CFM
11.Pro-M 80MM, 1612 CFM
Now, I coulda swore that a stock MAM was only 55 mm, not 58.. I read that in a few of the Ford hi po magazines... years back. Has anyone one here ever flow tested a stocker thats been hogged out from 55 to 60mm? The reason I ask, is because I am having a problem with my LX running lean and having some light detonation, plugs are white, and I DO think its C&L 73mm MAM related.
So, if, from that FAQ page a 65mm [which I have] T body, flows:
THROTTLE BODY AIR FLOW DATA (In CFM):
2.Accufab 65MM, 616 CFM
Then if a stock 55mm [or even if its 58 but I dont think so] MAF flows 606 CFM, then a 60mm MAF must flow close to the same as a 65 mm T body.. [cause theres no throttle shaft obviously]. And if thats the case, then, i'll put my bored stocker back on until I need larger injectors... but i'd like to know if anyone knows what a bored out 60mm stock MAM flows???
Thanks!
Cause See....
Thanks!
