873Stang New Member Jun 19, 2006 221 0 0 riverside Oct 31, 2007 #1 Oct 31, 2007 #1 hwo would i adj my stock rocker arms? i took the heads off and im putting it back together. thank you
PUNISHER RACING Active Member Aug 27, 2007 1,124 0 36 FORD CITY, PA. Oct 31, 2007 #2 Oct 31, 2007 #2 you dont adjust them they are bolt down
873Stang New Member Jun 19, 2006 221 0 0 riverside Oct 31, 2007 #3 Oct 31, 2007 #3 but when you bolt them down theres no filler gauge to use, and aren't both valves spose to be close when you tighten them?
PUNISHER RACING Active Member Aug 27, 2007 1,124 0 36 FORD CITY, PA. Oct 31, 2007 #4 Oct 31, 2007 #4 no feeler gauge used, just bolt em down you can rotate engine over to close the valves if you wish. in some cases a shim kit is used to get the lifter preload correct when you install new rockers or a different camshaft
