stock-style UCA for '68?
I need to buy stock-style upper control arms for my '68 Fastback. Can someone point me to vendor that sells such arms with ball joint mount modified for shelby drop? I searched but I could only find stock geometry arms. But I remember that someone offered modified UCA.....
You've actually asked two questions.
The "Arning/Shelby drop" does not require any modification of the arm or ball joint. The 'drop' is a 1" relocation of the upper arm, and does not produce bind in the ball joint. If you go more than 1", you need a negative wedge kit. Of course, more than 1" will give you geometry changes that will be a problem on the street.
Arning/Shelby Suspension Drop
If you are looking for correct 4-bolt 67-69 upper arms, Glazier Nolan lists them in their catalog. IIRC, they are considerably more expensive than the 3-bolt replacement style. The 3-bolt is actually just the stock 70-73 type. If you use them, you should also use the 70-73 rebound bumper.
Thank! Yes, I have only 1" drop. So, I can just buy 70-73 stock arms and they fit fine and don't change any steering geometry?
