Stock throttle body iac tps same as 65mm??
AnthonyR23
661
Ontario
Hi.. is the stock iac motor and tps sensor the same on a 65mm ford facing throttle body.. or are they different units.. and will the stock gaskets be the same or are they bigger.. from a local canadian tire it just lists the stock gaskets.. if there not the same will a ford explorer gasket work.. since I think they are stock 65mm throttle bodys... maybe... any ideas??
the gaskets are the same. they are cheap so while your putting new parts on, start with a fresh gasket..
but when i have parts apart i just keep the old gasket on, the IAC and EGR gasket usually stick to the TB so i just leave them there and bolt the stuff back on with no problems.
