  • 2.3L (N/A & Turbo) Tech
Stop STALLING!!!!
  • Thread starter Thread starter imapaintballa
  • Start date Start date Mar 10, 2007
I
imapaintballa
17
  • Mar 10, 2007
Okay, after replacing the ignition control module and starter switch and realy, my car has yet another problem. Just yestrerday, I was driving up the street and all of the sudden, my engine dies. No hesitation or any kind of bumpy idling. Just goes from 3500 to 0 RPM. I tried to start it, no luck. Waited 20 minutes, fuel pump finally started up when ke was in the ON position, started up. Drove it home. Today, started it up. Drove to the Schnucks (our supermarket in the MW). Came back out, car woldnt start, had fuel pump come on and cranked its heart out. Car wouldnt start!!! Finally got it started about 10 minutes later. I let the car idle at the stoplight. Once again it died suddenly. No signs of erradication. Please help my car!!! Thanks. -Adam
Keasbey
915
Montreal
Mar 11, 2007
  • Mar 11, 2007
clogged fuel filter?
bhuff30
6,037
35
129
Olathe KS
Mar 12, 2007
  • Mar 12, 2007
what year is it? if it is an 87-90, then it is probably the ignition modual (TFI). When these moduals get hot, they tend to quit working, so leaving it in parking lot to heat soak, or while driving it, they are the most likely to quit.
I
imapaintballa
17
  • Mar 12, 2007
its a 92, so if figure its the same, right?
351wcoupe
1,811
Manhattan, Kansas
Mar 12, 2007
  • Mar 12, 2007
Everynow and then I'll get a weird problem like that here at the dealership. Most of the time I cna't duplicate the problem since its intermitent.
For weird problems such as that Typically distributor parts....EI the aformentioned TFI module or the pick-up in the distributor. I had some problems with the 88 coupe and I replaced the EEC relay and never had another problem.
EIDT: Missed the part where you say its a 92. Sometimes the crankshaft sensor can cause some weird problems. For example. You migh thear the fuel pump prime for 2 seconds and the turn off when you turn the key on, but if its not seeing a signal that the crankshaft is turning it won't restart the fuel pump. Have somebody crank it over and try to listen for the fuel pump to turn back on after its cranking
I
imapaintballa
17
  • Mar 12, 2007
do you think it could be caused by a faulty ignition control module?
I
imapaintballa
17
  • Mar 14, 2007
found the problem!!! the wire harness for the relay box is either loose or dirty. it take a little wiggle to get the pump to prime.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
M
3.8 start problems. New edge 2003
  • Mayk.i.
  • Oct 2, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 3, 2025
manicmechanic007
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
G
Persistent P0102 and limp mode
  • Godless
  • Oct 30, 2025
2005 - 2009 Specific Tech Nov 11, 2025
Godless
G
