Story of a ghetto exhaust install
mijo_latino
179
Canton, Michigan
Well, put the exhaust on finally. Took me too long to even mention the time exactly(too humiliated). This was deffinatly a ghetto backyard install for the books. I thought i would share this experience with everyone:
Reversed car onto ramps
Got out the only power tool available, the hand ginder,
Throw a cutter on it and hacked away, mind the sparks!
To the bolts, rust pieces of junk, busted out the leg power for turning
those(should of bought rust loosener.)
Too bad leg power was too much and bent the last bolt & nut together
Hacksaw fixed that prob. Went to hardware store to find replacement nut.
No soap & water for the rubber thingys, thats for sissy's, heh.
Hmm, piping was hard to get out over the axle(figured that out later).
Fired up without mufflers, Sweeet!
Hmm, leave like that? Nah, can't afford the tickets just yet...
Install the leftside, adjustments were hell. oh the headache.
Install the rightside, oh wait, why can't the piping fit over the axle? AHHH!
"Turtle it!" well that didn't work, Jack and ciderblock did the trick of lifting
the frame long enough to get the damn pipe over the axle.
Adjustment
Adjustment
Adjustment.
The over adjustment happened and the exhaust clamp/nut snapped off
LOOSENING the thing, on both ends of the clamp. Back to the
hardware store for some clamps.
Finally everytihng is mounted, tighted, clearance checked.
Looks perfect, clean and just overall all good.
Clean up tools, stock junk, and lowered the car.
Fired it up and smiled.
"look at that, is the tip sticking out too much on the right?" i try to adjust
tip and....
Piping did not sit right and now with a slight bump the last part of the
exhaust misalligns and hits the axle/gas tank/ bumper.
.... ..... Well, i'll get it after work tomorrow..
:sigh:
Now im not done as of yet, need to rework that piping of the right side and do something about slight leaks here and there. Ghetto yes, but at least i did it myself with my bro and learned a bit more of the mechanics trade. It took my only day off this week and still am happy i didn't pay someone else to do it.That was the whole point, right?
"Turtle it"- to have one get on all fours and lift the frame with the back while the other person trys to manuever the pipe over the axle. Due to the quick exhuastion of the Turtle position, "Turtle it" will be no longer used as an effective method of lifting the rear frame of a car.
Smooth_Operator said:
You got under a car with out stands. :rolleyes: :nonono:
:lol:
Just because I don't own any yet doesn't mean I didn't borrow some. You assume a lot of stuff :) I didn't own any tools at the time of my cat back or x pipe install. My friend's let me borrow their tools and gave me a hand. I was shocked at how easy the cat back install was :)
I had jack stands for the cat back and ramps for the x pipe.
I need to get ramps. Today when jacking under the front plate between the suspension the jack slipped off and shoved a huge dent into my oil pan. Thought maybe it wasn't that bad so i cracked her over for about a second and from the noise i heard i knew the oil pan had to be dropped. Looks like my engine will be coming out as soon as i get time to yank it. BTW me, a friend and a reciprocating saw installed my cat back in about an 1 1/2 hours. he was very picky about the alignment. I was like just tighten the clamp and lets go ride. lol
JonJon said:
:lol:
Dude, I just want folks to be safe. With all the Rice out there we can’t afford loose one Blau. :nice:
Man that was a funny story to read... :nice:
I put mine by myself , it was a pretty easy install ( when you cut the stock one to remove them ).
The worst part was to align them , it took me a few weeks , always touching somewhere but I'm fine now !
Update
Well, I lifted the car again to readjust the right side. This time i had some experience from the day before so in only took me 30 min to adjust and take it over my uncles to use his impact wrench to tighten all the bolts.
Heh, I asked my dad how long it took him when he was building a racer back in the late 70's. 2 hours to gut everything from headers back on a cordora. Due to inflation, I think the hours match up, don't you all?
2hours in 70's---inflation---32 hours 30min. in 04' yup yup. Damn proud. :rlaugh:
Next stop, some bassani catback on bro's 01' GT. Im sure it will take only 2 hours max this time.
