Strange clutch problem
Skymarshal
572
Dallas
I have a wierd problem on my '92 5.0 LX convertible. It's always had a clutch that you had to absolutely mash into the floor to disengage after my father in law repaired a broken cable by welding a clamp on it at the fork end. It always confused me since a shorter cable should mean it would be easier to disengage...
I replaced the clutch cable with a stock new one, and for a while the clutch worked great. Then, all of a sudden while driving it, it stopped working. The clutch pedal can be pushed into the floor without disengaging the clutch. The cable is routed correctly over the adjustment cam, and the cable is unbroken and connected correctly at both ends. The adjustment cam is all the way out already, and no further takeup is available.
Any ideas what's going on here? The only thing I can think of is that the clutch fork is bent, or there's a problem with the throwout bearing. I'm hoping I've done something boneheaded and it will be an easy fix, but I'm starting to think a new clutch is in my future.
Clutch adjustment
Do the clutch adjustment first before considering any other problems. With the stock plastic quadrant and cable, pull up on the clutch pedal until it comes upward toward you. It will make a ratcheting sound as the self adjuster works. To release to tension of the stock quadrant, use a screwdriver to lift the ratchet paw up and out of engagement with the quadrant teeth.
A binding clutch cable will make the clutch very stiff. If the cable is misrouted or has gotten too close to the exhaust, it will definitely bind.
Clutch pedal adjustment with aftermarket quadrant and cable: I like to have the clutch completely disengaged and still have about 1.5” travel left before the pedal hits the floor. This means that I have only about 1” of free play at the top before the pedal starts to disengage the clutch. Keep in mind that these figures are all approximate. When properly adjusted, there will not be any slack in the clutch cable. You will have 4-15 lbs preload on the clutch cable.
The quadrant needs to be replaced if you use any type of aftermarket cable or adjuster. My preference is a Ford Racing quadrant, adjustable cable and Steeda firewall adjuster. The adjustable Ford Racing cable is just as good as the stock OEM cable. It allows a greater range of adjustment than a stock cable with a aftermarket quadrant and firewall adjuster. Combined with the Steeda adjuster, it lets you set the initial cable preload and then fine tune the clutch engagement point to your liking without getting under the car.
Using a stock OEM cable, firewall adjuster and a single hook quadrant may result in not having any free pedal travel before the clutch starts to disengage. I found this out the hard way.
The binding common to adjustable cables is often due to misplacement of the adjusting nuts on the fork end of the cable. This will also cause the cable to wear and fray. Both nuts should be on the back side of the fork so that the domed nut faces the fork and the other nut serves as jam or locknut to the domed nut.
I have all OEM components, and my clutch adjustment cam is already all the way out. Even so the cable is slightly slack by about 1/2".
I'm thinking I might have gotten the wrong cable, since this one is so long and has no adjustment at the fork end.
