Strange problem
  • Thread starter Thread starter 87foxstang
  • Start date Start date Oct 20, 2008
87foxstang
Cromwell, CT
Oct 20, 2008
  • Oct 20, 2008
I just encountered a very weird problem and wanted to see what you guys think. I was planning on going to a test and tune day at a nearby strip this weekend. 2 days ago I took the car out and adjusted the suspension to how I wanted it and took it for a ride. I warmed the tires up in 1st gear with a small break stand at about 5k rpms.
All of the sudden I hear a POP, backfired through the intake. Drove it 15 miles home going about 30 mph max, blowing black smoke out the tails. If i gave the car more that 1/4 throttle it would sputter and backfire. Obviously im burning excess fuel for some reason.
heres the weird part. The next day I start the car up and the thing runs PERFECT. I had went through all the injector connections, vacuum lines, MAP sensor and everything the night before and it still ran like ****, and the next day it runs fine...boggles me.
I pulled codes, and nothing. Any ideas guys Im stumped.
93 LX
3,081
Norwalk, CA.
Oct 20, 2008
  • Oct 20, 2008
fuel regulator could have stuck..... Sticky injector? Sticky EGR..... Did you pull codes?
87foxstang
Cromwell, CT
Oct 20, 2008
  • Oct 20, 2008
Yea I pulled codes, which got me nothing.
Also, I put a fuel pressure gauge on my schrader valve and at idle I have about 38psi, which I always have. When I shut the car off the needle dives down to zero in about 5-8 seconds. should the pressure drop off that quick?
bhuff30
6,037
35
129
Olathe KS
Oct 20, 2008
  • Oct 20, 2008
That seems excessivly fast for fuel pressure to drop to zero. Check for fuel in the reference hose to the FPR. Might be an injector leaking or temporarly stuck open too.
87foxstang
Cromwell, CT
Oct 20, 2008
  • Oct 20, 2008
There is not fuel in the vacuum hose that goes from the regulator to the manifold. Heres another weird thing. The fuel pressure did that when the car was running like crap. and it does it now, when the car is running fine
Is there a definite way to check for a bad fuel injector?
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
