Ok, my tach was geting jumpy the other day, some guys on here said it was more than likely a bad coil. I was gonna change it tomm but some other stuff started happenening. Today in the drice-thru, it started charging weird, but not bad. My radio would randomly cut off while driving, voltometer was fine. Radar detector started going off for no reason. My headlights would go dim when I turned the wheel while not moving. Then when I would start off from a dead stop, the voltometer would drop below 8 for under a second, my speakers would cut out for under a second, then everything was fine but the tach was still jumpy. Im thinking the alt may be bad.
So what do you think?
Im gonna get the alt tested tomm, if its fine, Ill change the coil and see what happens.
