Strange Tranny
  • Thread starter Thread starter stangmodifier
  • Start date Start date Jan 24, 2007
stangmodifier
85
Chapman Kansas
Jan 24, 2007
  • Jan 24, 2007
I'm working on an 85 v6 auto vert for my wife. I have pulled the engine and tranny from the car. I have an 89 5.0HO 5 speed motor. I pulled the clutch, flywheel and pilot bushing and bearing. I have a early 85 GT with cfi and auto trans. I pulled the trans, and flywheel. My question is what transmission do I have? It has the bellhousing as part of the casting like a c-6 or an aod, It has a "metric" pan , but it has no vacuum modulator nor any TV cable hookups. It does have a kickdown lever. It has the four wire harness for the shifter. The GT has the OD shifter in it but I think I can use the shifter that is in the vert they each only have three detents right? The tag on the trans reads:
PKA BW7
011194 J6
E5ZP EA
How is this transmission gonna know when to shift with no vacuum port, no TV port, and no unused electrical connectors??
ronburgundy
179
BC coast
Jan 24, 2007
  • Jan 24, 2007
sounds like an aod. you have to get the thottle valve linkage to the 'kickdown' lever.
ps it's not a kickdown lever it's a tv lever. totally necessary.
stangmodifier
85
Chapman Kansas
Jan 24, 2007
  • Jan 24, 2007
I thought it was a kickdown lever because it had a bent rod connected to the throttle body, like a c4 kickdown rod, not a cable. So that is where my TV cable will go? Ok, I am waiting for parts to arrive. I'm waiting on a 5.0 throttle and TV cable and brackets, a double hump crossmember, 86 5.0 harnesses. Thanks.
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
CFI to carb conversion question
  • StockerStang
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2025
AeroCoupe
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
Engine Bad engine shaking at idle
  • sav22rem22
  • Jan 2, 2024
6K
Fox 5.0 Mustang Tech Feb 2, 2024
sav22rem22
