Strange Tranny
stangmodifier
85
Chapman Kansas
I'm working on an 85 v6 auto vert for my wife. I have pulled the engine and tranny from the car. I have an 89 5.0HO 5 speed motor. I pulled the clutch, flywheel and pilot bushing and bearing. I have a early 85 GT with cfi and auto trans. I pulled the trans, and flywheel. My question is what transmission do I have? It has the bellhousing as part of the casting like a c-6 or an aod, It has a "metric" pan , but it has no vacuum modulator nor any TV cable hookups. It does have a kickdown lever. It has the four wire harness for the shifter. The GT has the OD shifter in it but I think I can use the shifter that is in the vert they each only have three detents right? The tag on the trans reads:
PKA BW7
011194 J6
E5ZP EA
How is this transmission gonna know when to shift with no vacuum port, no TV port, and no unused electrical connectors??
I thought it was a kickdown lever because it had a bent rod connected to the throttle body, like a c4 kickdown rod, not a cable. So that is where my TV cable will go? Ok, I am waiting for parts to arrive. I'm waiting on a 5.0 throttle and TV cable and brackets, a double hump crossmember, 86 5.0 harnesses. Thanks.
