Stroker Kit?
  • Thread starter Thread starter load71
  • Start date Start date Jul 31, 2005
load71
68
  • Jul 31, 2005
Well the time has finally come. What brand kit should i buy. Its the orginal block, so there is no need for all forged. I want a 331, and it is going to have the trick flow package with it. What brand/kit should i get? D.S.S., Chp, Scat? Thanks
runningmole
1,127
San Diego, CA
Jul 31, 2005
  • Jul 31, 2005
Where are you located? I have a Hawaii Racing (Simi Valley, CA) 327. You may want to get a forged setup. I bet you're thinking you'll never add boost or nitrous...but you will
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jul 31, 2005
  • Jul 31, 2005
Yep, you don't need to waste your money on a forged stel crank shaft in a stock block. Its just gonna add rotational weight. I use a scat cast steel crank, probe/chp ultra light I beam rods and probe srs forged pistons.
I'd do something a bit better than a trickflow street/track package on a 331.
load71
68
  • Aug 1, 2005
You think the package is too small? Do you think the intake is too small, or everything in general? I really dont want to spend the extra money to get afr heads, custom cam, and having to buy seperate.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Aug 1, 2005
  • Aug 1, 2005
If your looking for a mild engine that'll make power to the rev limiter, the track heat intake might work ok. The stage 1 cam, however, will not. You can use the TFS heads and track heat intake but a custom cam is a must. You have a heavy aod convertable, a custom cam will provide better power across the tach for you. You will be upgrading your valve springs.
Rick 91GT
Mustang Master
95
99
PA
Aug 1, 2005
  • Aug 1, 2005
I agree with a heavy vehicle the cam can really make a big difference... The springs that come with the TFS Track Heat are pretty decent and can take some custom cams with asymetrical lobe profiles.
The Stage 1 is a little small for a stroker combo IMO.
If you need help with spec'ing or purchasing a stroker kit or engine I would be glad to help you. You don't have to buy from me if you do not like but I can atleast put you on the correct path based on first hand knowledge.
vristang
4,933
101
124
Seattle
Aug 1, 2005
  • Aug 1, 2005
As far as what brand to get I can't help much, other than sticking to reputable manufacturers. If the pistons are made by a company called PIM Inc. (Plastic Injection Molders) based in S. America, I would say don't buy it, no matter how cheap.
A problem I had was that my kit was sold with low tension RACE rings. These are used for racing applications that require low ring friction. Unfortunately they also produce tons of Blowby. After a couple thousand miles I got 20% on a leakdown test. Make sure you know exactly what rings you are getting, and check with the ring manufacturer to make sure they are appropriate to your application. The same can be said for the bearings. A little extra time now will save you from having to rebuild within 5k miles.
I would also recommend a slightly larger cam for the stroker. Probably a Stage 2 at least, or similar grind from Crane, Comp, etc. Added cubes will generally prefer more lift and duration. I have seen recommendations for LCA as well but I will have to look that up when I get home. Let me know if you are interested, otherwise I will forget. Will you have to pass emissions with this car? This may be the most important factor to consider when picking a cam.
Good Luck
load71
68
  • Aug 1, 2005
Thanks for the replys guys. Rick i would love your help, and i wouldnt mind at all buying the stuff from. You have helped a lot of people out here, and i think it would be great if you help me. No i am not worried at all about passing emmisions. So do you guys think it would be better off buying everything seperate instead of the kit?
txstang84
1,639
42
69
Tuscola, tx
Aug 1, 2005
  • Aug 1, 2005
if you find a kit for either 331 or 347 with a cast steel or nodular crank, 5140 or 4340 rods, and forged pistons for around 900-1100 that's a decent price. they can be had for cheaper, but alot of them include the KB pistons which are good, but I'd rather take the forged over hyper pistons for high performance app's.
I sourced all my parts separately for $960 total cost including bearings scat cast steel crank, 4340 cap screw doweled rods, probe dish pistons, total seal rings, and clevite bearings. I figure there's no point in putting forged parts into a block that can't handle the abuse...
vristang
4,933
101
124
Seattle
Aug 1, 2005
#10
  • Aug 1, 2005
  • #10
Personally, I would go with the kit as opposed to selecting the individual parts yourself. This way it will be more likely for you to have the right bearings for your rods, right rods for you crank, and right rod pins for the pistons. The list goes on. When you order though make sure they know that the car will be a driver and whether or not it will ever see boost. Have an idea of what rings/bearings you want before you call so that you are happy with what the UPS guy brings you.
Rick 91GT
Mustang Master
95
99
PA
Aug 1, 2005
#11
  • Aug 1, 2005
  • #11
Load71 what is your e-mail address?
A
Andres2882
316
#12
  • Aug 1, 2005
  • #12
I second the notion of going with Rick if at all possible. He basically held my hand through a whole long block build and went out of his way to make sure I understood everything. Upstanding and hella knowledgable. Now if only I can get together enough cash
load71
68
#13
  • Aug 1, 2005
  • #13
VernJ33@aol.com
Thanks a lot rick!
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
