load71 said:Well the time has finally come. What brand kit should i buy. Its the orginal block, so there is no need for all forged. I want a 331, and it is going to have the trick flow package with it. What brand/kit should i get? D.S.S., Chp, Scat? Thanks
Grn92LX said:Yep, you don't need to waste your money on a forged stel crank shaft in a stock block. Its just gonna add rotational weight. I use a scat cast steel crank, probe/chp ultra light I beam rods and probe srs forged pistons.
I'd do something a bit better than a trickflow street/track package on a 331.
Grn92LX said:If your looking for a mild engine that'll make power to the rev limiter, the track heat intake might work ok. The stage 1 cam, however, will not. You can use the TFS heads and track heat intake but a custom cam is a must. You have a heavy aod convertable, a custom cam will provide better power across the tach for you. You will be upgrading your valve springs.
