  • 1994 - 1995 Specific Tech
Stroker recomendations??
  • Thread starter Thread starter vp6799
  • Start date Start date Apr 17, 2007
vp6799
124
Massachusetts
Apr 17, 2007
  • Apr 17, 2007
I'm building a new motor which will be running a vortech s-trim blower kit. I was originaly gonna keep it as a 306, but figured what the hell. Since it's all apart, I might as well go big.
By doing a search on here and other forums, I came up with going the 331 route due to me wanting a very streetable setup. I don't want to run into oil burning or bearing problems like i've read about with the 347 strokers.
My question is what company do you all recomend buying from?? I've found kits from DSS, CHP, and SCAT that seem reletivaly close component wise. I've read up's and down's about DSS and CHP, but can't find any info on SCAT. I am looking for a quality and dependable kit to use.
My combo will include: Holley Systemax intake, AFR 185 heads, vortech s-trim. I'm still up in the air on a cam to use also????
:SNSign:
Vic
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 17, 2007
  • Apr 17, 2007
For what it's worth, I've read in many places that the oil consumption problem with 347 strokers is essentially solved. Some of the cheaper (eBay type kits) still may have this problem, but using one of the big companies like the ones you mentioned should allow you to avoid it.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 17, 2007
  • Apr 17, 2007
A few things to think about:
I would get an aftermarket block...the stock block will have trouble staying together with a stroker and blower. That cost $$$.
If you plan on 'big' power and 'big' boost, consider the 331. The 331 piston has more material to it, which is more ideal for big boost.
A 347 would work just fine but I would recommend getting the 5.315" rod instead of the 5.4" rod. The latter has the wrist pin boss that intersects the oil ring. It is more likely to let oil blow-by occur later on down the road.
Either will work just fine, I would recommend the 331 from personal preference. Power numbers will be very similar either way, good luck
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 17, 2007
  • Apr 17, 2007
331 or 347
If you were gonna go NA ... I'd tell you to go for the cubes
Since you talk about Forced Induction .......
I gotta admit ... Things change with all that and I can see some good
points about going with the smaller cubes.
Some have run oem blocks for a long time and had no probs
but
Others have not been so lucky
I've seen so many preach about good tune and keeping things
sensible (boost) is the key to doing it with just an oem block
Good Luck
Grady
vp6799
124
Massachusetts
Apr 17, 2007
  • Apr 17, 2007
Yes it's an OEM block out of a 98 exploder. I will be using that for the build. I don't plan on running the blower at max psi. I have read about OEM blocks not taking power well, but i'm not the beat the hell out my car person. I do plan on getting a good tune and will be picking up either a tweeker or a PMS system.
So I guess I should stay with a 331 stroker instead of the 347 due to the blower. Would I be better off going 306 and the blower, or 331 and blower??? I know more cubes is better to some, but I want reliability.
Vic
Y
yellow1995Cobra
2,959
Massachusetts
Apr 17, 2007
  • Apr 17, 2007
Most of the 347 downside myths have been debunked. Dont let any of that BS stop you from going that route. I went the 331 route basically just cause its different, seems like everyones running around with a 347 these days..
Like said above, power #'s will be similiar with either size motor..
vp6799
124
Massachusetts
Apr 18, 2007
  • Apr 18, 2007
Hey man, where abouts in mass are you located, and do you have any pics of your build??
I do believe that I will go with a 331. Now I have to figure out what company to deal with. I'm leaning towards CHP because i've heard some horror stories from DSS lately.
Vic
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 18, 2007
  • Apr 18, 2007
306 will make less power but be safer towards the block for that very reason.
Many are doing the rebuilt 302 with h/c/i and blower route with good results...
You start upping the cubes you start cracking the stock blocks If you really are stuck with a stock style block, atleast get a girdle so you can save some parts when/if the block cracks.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 18, 2007
  • Apr 18, 2007
Vic
I gotta tell you Vic ...........
I really don't see reliability issues with either 331 or 347 myself
I base that upon what you say here
Now ... when I said 331 for forced combos might be more desirable .....
I should have said if going for a good bit more power that the
typical OEM block based Street Car Combo.
I have often thought about a forced combo myself
So ... when you see the amount of performance many have got from
an OEM block ... Well I see it as really amazing
So many say you can do 400 to 450 rwhp with not much of a concern
of splitting the block as long as you use good common sense like was
talked about above.
Now ... when talking about 331 or 347 ...........
You start to get into higher quality machine work and parts
Not necessarily so if talking about a 306 ... don't ya know
Having said all that ............
Here is a thought
You could do a nice bore clean up on your existing motor for
a dandy little 306
and
The money you would have spent on machine work and fancy parts
Put it toward a PMS, SCT, or Tweecer with Wide Band
cause
I can tell you this my friend ... Self Tuning ... It ain't cheap
Grady
m0l0
178
Apr 18, 2007
#10
  • Apr 18, 2007
  • #10
Grady
x10000
About 1/3th of all the money invested on a H/C/I will go towards fuel support mods + tunning, but hey look it optimistic once you are there you can do whatever you want with your stang. Changing latter parts is just a little wrenching and some time on a laptop.
Y
yellow1995Cobra
2,959
Massachusetts
Apr 18, 2007
#11
  • Apr 18, 2007
  • #11
Vic
Im in saugus, about 10-15 minutes north of boston.. Where you at?
Heres a few pics...
Prior to engine bay painting and jet hot coating on the turbo system..
New motor mocked up..
And where im at now, i need to put the tranny in this weekend to finish up all the engine bay stuff since i need the motor to be level..
vp6799
124
Massachusetts
Apr 18, 2007
#12
  • Apr 18, 2007
  • #12
I'm in Fall River, about 30 min south of boston. That's a sweet setup you got there. Good luck with it.
Vic
vp6799
124
Massachusetts
Apr 18, 2007
#13
  • Apr 18, 2007
  • #13
talked about above.
Here is a thought
a dandy little 306
and
cause
Grady
I have decided to go with a 306 and the blower. Can't wait for the tunning part...
I am thinking about the tweecer rt system, what's the pms system and how is it compared to the tweecer?? Also is the sct a tunner like those or a chip??
Thanks
Vic
Pokageek
2,767
MA, USA
Apr 18, 2007
#14
  • Apr 18, 2007
  • #14
final5-0 said:
331 or 347
but
Good Luck
Grady
DITTO x3. I said #$%^ it . I am going 408. i will be hitting 500hp n/a and I will have the option to s/c.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 18, 2007
#15
  • Apr 18, 2007
  • #15
Thanks
Vic
I don't know a whole lot about the PMS other than it is more easy to
use than the Tweecer
Heck ... Everything else is easier than the Tweecer
We have several PMS users here and maybe they will give some
details for you.
Yes ... SCT is a self tuning option like the PMS and Tweecer. For our cars,
I believe the particular one used is called the Pro Racer.
You can look elsewhere in the tuning forum because I know Don has given
a few details about it or look for posts by the member name of
Don 95Vert and use the link in his sig to go to his site.
Grady
vp6799
124
Massachusetts
Apr 19, 2007
#16
  • Apr 19, 2007
  • #16
details for you.
Grady
Awesome, Thank you guys for the help and info.:SNSign:
So I take it the tweecer is a ****** to use huh.... I guess i'll look into the PMS and SCT systems. Never really heard info about SCT, so i'll look into it. I will search for that user name you said for info.
Now I just gotta contact either CHP or SCAT for pricing for the 306 stuff.
Thanks again
Vic
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
TTSaleen's Foxbody Project
  • TTSaleen
  • Apr 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
TTSaleen
