strut brace
kdogg_60
Charleston
what about a front strut tower brace for a 03 gt. did anyone notice an increase in stiffness? worth the purchase or no.
just looking for some more stiffness and eventually going to upgrade the suspension
I noticed a huge difference when I added MM strut tower brace and 4 pt k member brace to my GT. Going up a driveway or over rough broken pavement chassis movement and noise was all improved. I drove with just those while I was waiting to add the subframe connectors.
Yes, the relatively inexpensive way to do this is to find the convertible sub frame connectors and the k-brace. Because I ran in the "stock" class this is what we had to do, however, weld ins are much better, not only are they more substantial, but they're less prone to flex becuase they are welded. It just depends on what you want to do, a "good" stock set up like I ran meant the convertible parts, like I mentioned, the biggest rear sway bar known to mankind, either a convertible or off of a mid 80's Fairmont wagon are two good places to start, Tokico non adjustable shocks from Ford performance and a cut set of springs to lower the car. Use the Steeda bump steer kit with the extended ball joints to get the roll center back up out of the pavement (that bit of info actually made a HUGE difference in handling).
http://www.steeda.com/products/x2_balljoints.php
http://www.steeda.com/products/bumpsteer_kit.php
If you don't have to conform to rules, you could substitute aftermarket parts, but this will give you a real good starting point for a street car. If there was one area that I would change, it would be to buy aftermarket springs, and don't mess with the stock front sway bar, leave it alone.
A big +++ on the Watts link, for some reason ($$$) Ford tried to make the rear end components do too much work, like both locating the rear side to side and front to back. The watts linkage takes care of those ills, Steeda and others also make those similar parts, I tend to go with Steeda because they're 50-75 miles away, but there are other companies as well.
I just wish we could've run that stuff.
You know, I was thinking, you could probably fab up some upper arms with heim joints and build a panhard bar, it would do about the same thing, the Watts is still better, but it might be a low budget alternative. FWIW
There's also a "Jacobs ladder" which is lighter and cheaper, but not as strong, I've really wanted to try this, but it would have to built way heavier.
http://www.speedwaymotors.com/p/654,754_Aluminum-Jacobs-Ladder.html
http://www.steeda.com/products/5link_2rear.php
