Strut Rod Bracket And Anti Sway Bracket Measurements
i have a pic .i can get you some measurements tomorrow
all measurements will be from the front crossmember and from the outer edge of the bottom of the frame rail
starting with the sway bar bracket ,because it will weld in first. from the end of the cross brace below the radiator support to the back edge of the sway bar bracket is 17 1/2 inches . the side is self positioning .
from the front of the cross brace again on the radius rod bracket to the end is 13 inches. at the front of the radius bracket it is 9 1/8 inches from the side of the frame rail . from the side of the frame rail to the rear of the radius bracket is 7/8 of an inch. measurements will be the same for both sides. this car has never been wrecked so i know they are correct measurements .good luck
Hey. I bought a anti sway bar bracket from mustang unlimited. The two holes do not match up. Should I be worried. I measured and I am a half inch off. Should I be worried
