squares98 said:FYI Smart Saleen S281sc owners upgrade to K.B. Be that person.![]()
the saleen will do damage just as fast as a KB on an engine that isn't setup properly or poorly tuned. They are similar superchargers but the KB is the better unit overall and i think it might be cheaper. BUT if your trying to complete your Saleen look i understand why you would want the Saleen blower. I'd be happy with either but would buy the KB but its your moneySeraphitia102 said:I've heard of many people with stock motors being blown or ruined because of Kenne Bell SC's. They do make a lot of power, but I'm also looking for a "safer" boost since it's also my daily driver. I heard from Chicane Sport Tuning that while Saleen SC's don't make as much power, they're a reliable source of it.
That's the most retarded comment I've ever heard. Who cares if every one on this board doesn't have a Kenne Bell blower. If you really want to split hairs about "Smart Saleen People"....I would image that the smart ones don't sink top dollar into a factory supercharged Saleen, just to swap it out with a Kenne Bell unit afterwords! The smart ones would buy the exact same car in N/A trim and buy the other blower right off the bat, instead of going through the trouble and expense of removing and selling the Saleen unit...and then the trouble and expense of buying and installing the Kenne Bell unit right after that.squares98 said:FYI Smart Saleen S281sc owners upgrade to K.B. Be that person.![]()
Gearbanger 101 said:That's the most retarded comment I've ever heard. Who cares if every one on this board doesn't have a Kenne Bell blower. If you really want to split hairs about "Smart Saleen People"....I would image that the smart ones don't sink top dollar into a factory supercharged Saleen, just to swap it out with a Kenne Bell unit afterwords! The smart ones would buy the exact same car in N/A trim and buy the other blower right off the bat, instead of going through the trouble and expense of removing and selling the Saleen unit...and then the trouble and expense of buying and installing the Kenne Bell unit right after that.
...and for the record, the Saleen Series IV will make every bit the power that the Kenne Bell unit will at reasonable street levels and more than enough to push past the limits of the stock short block. It's only when you really start spinning them (into the 12-14psi and 450-500hp levels) that the Saleens lower manifold becomes a restriction.....but by that point, both engines require internal upgrades and a steady diet of race fuel to keep them together anyway, so what's the point of bitching about blower limitations?
This is true, perhaps I was being a little optimistic with regards to the complete kit. Without some work to the manifold and addressing the sealing issues associated with the intercooler brick (not to mention the stock Series IV unit comes with a stock size 65mm T/B) seeing comparable numbers might be a challenge. The point I was really trying to elabourate on was with regards to the blower itself. The Series IV uses a Screw Type unit (1600AX), just the same as a Kenne Bell does. It's every bit as effiecient and capable it just needs a little help with the accompanying components.jstreet0204 said:This is all true except your power numbers are off. The saleen blowers won't break 400hp without a considerable amount of work.
Gearbanger 101 said:The Saleen manifold isn't exactly that complicated a piece and is realativley easy to port (which by the looks of it, you already know). To even have it extrude honed would be of great benefit. The sealing issues with regards to the intercooler brick can be cured easily as well....
Gearbanger 101 said:BTW jstreet, have you ever had your car dyno'd with the Series II on it? It utilizes an M90 the same as my Allen kit, does it not? It would be interesting to see how the two stack up against one and other.![]()
