  • SN95 4.6L Mustang Tech
strut tower brace???
  • Thread starter Thread starter seany425
  • Start date Start date Apr 12, 2005
seany425
90
  • Apr 12, 2005
i was thinking of puttin a strut tower brace in....is it an easy install and will i feel a difference in the handling at all will it feel stiffer???
StangPro
441
Roseville, MI
Apr 12, 2005
  • Apr 12, 2005
Install difficulty depends on which one you go with. Some like the Kenny Brown are simple installs, others like the EvM take quitea a while.
As long as you get a good three or more point brace, you'll feel the difference especially in hard corners.
R
RedLine01
148
MaComb Twp., MI.
Apr 12, 2005
  • Apr 12, 2005
Kenny brown strut was one of the first mods I did and I can tell you mine was not that easy. Since 2001 I believe they have made some changes because mine bolted thru the firewall and also took the place of the stock caster plates. So after the install I ended up needing a quick wheel alignment. I will tell you thou that sub frames connectors are a lot more noticeable then the strut brace…
Of course this is only my opinion
StangPro
441
Roseville, MI
Apr 12, 2005
  • Apr 12, 2005
You ropinion is true. SFC's make the most difference.
The KB still mounts as you described, but a quick alignment check is easy to most people than drilling all the extra holes other brands use to mount at the strut tower. The KB is a very nice piece.
The EvM unit is the bear. It's a 6-point brace and requires drilling 8 holes, adjusting the height and width and relocating some stock parts. It's very nice, but installation takes forever.
seany425
90
  • Apr 12, 2005
well i have the shaker system so i was gonna go with the mach 1 strut tower brace from mustang tuning is this a good one?
R
Rocketman
730
SoCal
Apr 12, 2005
  • Apr 12, 2005
MM has a very good STB. Here's a link for how to install one. http://www.stangfreak.com/StrutTowerBrace.html
StangPro
441
Roseville, MI
Apr 12, 2005
  • Apr 12, 2005
The Mach brace is good, but watch which one you get. There's a two point and a three point and you'll want the three point.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Apr 12, 2005
  • Apr 12, 2005
I have FRPP one, and it was bit pain to install. as far as handling goes....I can't tell if it changed or not. but with my car lowered, I figuredd its a good investment
Tylerb59
Banned
Mar 7, 2003
1,895
Arlington, WA
Apr 12, 2005
  • Apr 12, 2005
If you get a chance, thread the holes so it can bolt in.
The nut / washer / bolt bit is a pain to install and remove, especially around the firewall.
Indiana
286
#10
  • Apr 12, 2005
  • #10
I have a Kenny Brown, and do to the impending KenneBell, I ordered a Maximum Motorsports bar.
The reason is that everytime you have to take the sway bar off, your alignment gets screwed up with the Kenny Brown one.
Jones331
Banned
Oct 2, 2004
142
Oakland CA
Apr 13, 2005
#11
  • Apr 13, 2005
  • #11
Do those things clear the Kenne Bell on a 2v?.....jj
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
Apr 14, 2005
#12
  • Apr 14, 2005
  • #12
Sway bars make a way bigger difference in handling that a Strut tower brace.
Indiana
286
#13
  • Apr 14, 2005
  • #13
If you're talking to me, MM says they do.
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Frame rail strut tower repair
  • Creomod
  • Dec 5, 2024
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Creomod
