do you still have the MM brace?vristang said:I used an MM brace with a Cobra intake and about 3/4" spacer. The brace did not come over the top of the intake, it was off to the side. I think the vortech is wider though?![]()
I did like the MM brace. The only reason I don't still use it is that it does not clear the dist on the 351w motors.
larrendeuce
I will have to look into that Steeda unit. Thanks for posting that tasty morsel!
slow93 said:do you still have the MM brace?
srothfuss said:Hence, did you have to drill holes for mounting that brace...
