Stuck screw in awkward location, please help with removal suggestions
bcmbcmbcm
Jan 29, 2003
455
Hello,
I have a stuck phillips head screw in the upper drivers side corner holding the instrument cluster housing (black plastick, 1987 Vert) down. I need to get this off to get at my tach. I can't push down because the windshield is there, and clearence is very, very, tight. A stubby #2 phillips does not fit. Anyone have any other ideas?
Thanks in advance,
Brett
you can get ratcheting 90* screwdrivers from most hardware stores. they'll hold regular screwdriver bits and help a hell of a lot in tight spots.
they're 7-10 bucks at sears depending on how many bits you want with it. the sears item number is 00941716000 if you want to check it out at their website
