  • 1994 - 1995 Specific Tech
Stud mount and Pedestal mount rockers : pros and cons?
  • Thread starter Thread starter fiveoho
  • Start date Start date Feb 1, 2008
First Prev 2 of 2
95Vert
1,785
North Mexico (deep south Texas)
Feb 2, 2008
#21
  • Feb 2, 2008
  • #21
Mine are also 7/16 stud. The reason for having all this work done to my heads is because I want to run the times that others run with aluminum heads, low 12's/high 11's, then upgrade AFTER that. I've always had a 'Do more with less' attitude towards racing.
fiveoho
1,958
TN
Feb 2, 2008
#22
  • Feb 2, 2008
  • #22
with stud mount, i should use hardened pushrods specific for guideplates? any suggestions and what length? links would be great
as far as rockers go, could i use these ( the proforms are all but new but i just hear so much negative stuff about them ) ?
http://store.summitracing.com/partdetail.asp?part=CRN-11747-16&autoview=sku
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 2, 2008
#23
  • Feb 2, 2008
  • #23
fiveoho said:
these are actually 7/16 stud
the heads come with 3500 miles proform rockers. those would be sold and the money would be put toward a better/different set
I'm pretty certain you and I are talking about different kits here
The kits I've seen allow for no machine work what so ever
Thus ... you end up with a 5/16" stud on the bottom that will screw in the
unmodified OEM hole.
At least that is how I remember those kits I've seen over the years
If my memory fails me
Just flush this poopy info
Grady
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 2, 2008
#24
  • Feb 2, 2008
  • #24
Yes ... I've seen it said they've exploded thus sending roller bearings down
the oil drain holes
I'd take a pass on them
Grady
Zero Signal
2,633
Tucson, AZ
Feb 2, 2008
#25
  • Feb 2, 2008
  • #25
The answer to the original question is easy.
Stud mount are better for a few reasons:
  1. They use larger (stiffer and stronger) studs
  2. They are adjustable, most peds require shimming which sucks
  3. There are far more choices of stud mounts in the aftermarket for the above reasons
fiveoho
1,958
TN
Feb 3, 2008
#26
  • Feb 3, 2008
  • #26
thanks guys for the info
ford302redneck
85
Hartsville, SC
Feb 3, 2008
#27
  • Feb 3, 2008
  • #27
Grady, what would this section be without you?
lol.
fiveoho
1,958
TN
Feb 3, 2008
#28
  • Feb 3, 2008
  • #28
well, i -was- going to buy these heads monday. someone beat me with the money
First Prev 2 of 2
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
Resolved Noisy Valvetrain
  • PonyGTrider
  • Jun 15, 2024
4K
Fox 5.0 Mustang Tech Jun 19, 2024
PonyGTrider
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
