Studded Heads
  • Thread starter Thread starter 347 Pony
  • Start date Start date Feb 7, 2008
347 Pony
36
Sterling, VA
Feb 7, 2008
  • Feb 7, 2008
Is it possible or a huge pain in the rear to remove heads that are studded while the engine is in the car. I was looking at it last night and it looks like I might have some clearence issues on the drivers side with the brake booster. I am going to start tearing it down tonight and would like to know if I should just pull the motor or not?
347HO
462
Seattle
Feb 7, 2008
  • Feb 7, 2008
EFI or Carbureted makes a difference also.
If the Headers aren't an issue... you can nudge the engine to the side for more clearance from the booster.
It's normally not a good idea to attempt to remove the studs from the block... that's the whole idea behind using studs. Some have stripped the block, and more than a few have stripped the studs doing this. If you were the person who first installed the studs, and you used some type of antisieze... you might have luck getting them out?
MrXCESSIVESPEED
Maryland
Feb 7, 2008
  • Feb 7, 2008
Not impossible but def more of a PITA.
Maybe try pulling the studs in the area of concern?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 7, 2008
  • Feb 7, 2008
Edited, for the correction. 347HO is right.
Unscrew the studs with the allen wrench, assuming it has those provisions.
347HO
462
Seattle
Feb 7, 2008
  • Feb 7, 2008
When you have cylinder heads studs... you must install and remove the head evenly. It's the only possible way.
In your suggestion, you'd have to remove all or none.
347 Pony
36
Sterling, VA
Feb 7, 2008
  • Feb 7, 2008
It is fuel injected, with long tube BBK's, I 'm pretty sure I am going to need to remove the headers totally to do this anyway
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Feb 7, 2008
  • Feb 7, 2008
the headers will have to come out for sure.
when i installed my head studs. i put the heads over the dowels and just ran the studs in by hand and then put the nuts on, i am fixing to take the heads back off tomorrow and i will pull the headers and just the upper studs. if i leave the lower studs it will only have to come straight up a few inches, the long studs would cause the heads to hit the BB or the ac condenser, from what it looks like.
347 Pony
36
Sterling, VA
Feb 8, 2008
  • Feb 8, 2008
I loosened the motor mounts and jacked up the motor, this gave me enough room to remove the headers and remove the heads while leaving the studs in place.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
R
Help finding where this ground goes on the L head
  • RubberDuckUsb
  • Sep 11, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Sep 11, 2026
RubberDuckUsb
R
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
