  • 2.3L (N/A & Turbo) Tech
stumbling
  • Thread starter Thread starter shanetillery
  • Start date Start date Nov 7, 2006
shanetillery
  • Nov 7, 2006
ok I have 92 mustang 4cyl the car has been running great but last week it started running like crap. I ran the codes and got a faulty maf so i replaced it.
running good with the exception of serious hesitation on takeoff till about 2000 rpm the it comes alive(well as alive as a 4cyl gets ). I have vacume checked the egr valve it holds vacume and moves back and forth going to take it off and clean it tonight hope it helps
Here are the two codes I am getting
1 insufficiant egr flow dected
2 hegosensor voltage indicates lean bank one
I will try cleaning the egr tonight see if it help
any ideas would be nice I heard that when the tfi modual is going out it will cause a low rpm hesitation is this true?
what about a clogged cat, if it was clogged it would make the car run rougn at all ranges?
kiddiccarus
The first widely accepted Tranny
20+ Year Stangneter
Dec 24, 2003
1,789
1,051
143
30 Mins from a Ragged GT
Nov 8, 2006
  • Nov 8, 2006
I looked at the bottom of the reply box and seen some "similar threads"
http://forums.stangnet.com/showthread.php?t=657503
its worth a try.... there are others too, seems every make of Stang is having a issue like this
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Dies at start up, mild surge
  • Dontknowchit
  • May 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2025
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
