Stumped
slave4thestang
ok, my 87 5.0 gt is running terribly. it seemed liek it was runnign rich so ireplaced the coolant temp sensor. no luck. its nto blown head gasket the timign is dead on and it passed compression. its sparkign oragne on all cylinders so doyouthink my coil took a dump or coudl it bemy computer went tits up. because the vacum lines are goodthe fuel pressure regulator is fine and the cap rotor wires and plugs are new same withthe o2 sensors and the egr valve.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Wal-Mart may now have the LCD display scanner for less than $35
slave4thestang said:
oh no the iac is fine. its brand new. i had to redo the throttle body when i got it it woudlnt idle worth a damn.
Speaking of brand new IACs, what brand is it? It's a nice idea to make sure the IAC mounts conventionally - some don't. And sometimes when idiots in stores open a box, dump and stare at the contents, and decide they don't want it, they toss the little note indicating the need for the unusual mounting.
I actually couldn't follow what it is that's wrong with your car, so this might be neither here nor there.
Good luck.
this might seem weird but make sure your distributor turns freely..mine wouldnt and i overlooked it for a little while till i pulled it and noticed it needed about 30 ft/lbs of force to turn, then i figured out why my car would run pig rich and shudder violently below 2500 rpms..it wasnt sparking fast enough
Good luck.
I had the same problem, so I guess it isn't just me..
English is sometimes a second language for people who don't have a first language...
