Stupid Brakes
  • Thread starter Thread starter rustang87
  • Start date Start date Nov 26, 2005
R
rustang87
70
Sac
Nov 26, 2005
  • Nov 26, 2005
I need to beef up the front brakes bad. I have already replaced the MC, It was a crappy rebuilt one. The pedal is still mushy, going to the floor if I try. It has been properly bled a few times. The pads and rotors in the front are fine, and the fliud is full. How do you check drums? How do you adjust them? Should I replace the drum parts with oem parts? Who makes a twin piston caliper that fits under ponies for the front?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Nov 26, 2005
  • Nov 26, 2005
1) Drum shoes should be adjusted with the star adjuster at the bottom of the setup. use a flat blade screwdriver on the "star" adjuster to move the shoes out until the drum will barely fit over the shoes.
You can also drive backwards (in reverse) for 20' and then slam on the brakes and they will self adjust.
2) To get brakes that fit under ponies you will need to run a 12" rotor. To do this, you can run any PBR caliper / rotor setup off a '96-2004 Mustang. You will need to change the MC to a 94+ unit but that should be all if you can find the set at a JY.
R
rustang87
70
Sac
Nov 26, 2005
  • Nov 26, 2005
Who is PBR? A set up from 96-04? Isn't that all five lug?
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Nov 26, 2005
  • Nov 26, 2005
Yeah, if you went the OEM route you would have to switch to a 5-lug setup which means new rims and tires.
Baer makes a 4 lug kit in a 12 Inch rotor that will clear the pony rims. It's probably just what you are looking for.
R
rustang87
70
Sac
Nov 26, 2005
  • Nov 26, 2005
Right on man, I'll look into it right now
PM's aren't working for me cause the pop up blocker. Thanks
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
Brakes Brake caliper ID help
  • kidott
  • Sep 2, 2025
Fox 5.0 Mustang Tech Sep 2, 2025
AeroCoupe
