Stupid but..how many quarts on an oil change??
Thanks a lot.
Weird thing is i let her drain till not a drop came out, put some in the filter, and the balance of 6 quarts in the pan. Yet it still reads higher than full. Should i drain some? I don't get it. Thanks
Your overcomplicating something really simple. Ford specs 6 qts for the s197 4.6 3 valve engine. Drain your oil till it drips, no need for it to completely stop. Pull your filter off, check that the gasket is not stock on the oil filter mounting adapter. lube the gasket on the new filter and screw it back on. Then fill the engine. Run it for 30 secs. Shut it off. Wait about 5 mins. Check your level. It should be around full. A lil over is not gonna hurt anything. Even a lil under full is fine. Its when its at the first notch at the bottom that you need to add oil.
Ford recommends 6 qts, thats what was on all the ford literature i received from ford as well as its in the owners manual. Ford never said 6.5, someone jus said there specific dealer recommended 6.5. Jus fill it with 6 and youll be fine. What is so confusing?
Thanks to you, there's no longer anything left to be confused over...I'm just relieved that I had the correct amount of 6 quarts from the very beginning...:nice:
No problem bro. This is coming from a tech that would be filling it with 6 if he had an s197 for his own car. I promise you nothing will ever happen to your engine filling it with 6.
the ford manual does indeed state 6.0 quarts. this always puts the level midway on my dipstick. the proper operating level is in the crosshatch are on the dipstick.
