  • 1994 - 1995 Specific Tech
Stupid plastic vacuum lines
  • Thread starter Thread starter Zero Signal
  • Start date Start date May 23, 2010
Zero Signal
2,633
Tucson, AZ
May 23, 2010
  • May 23, 2010
Does anyone know where to get replacement tubing for those small rigid vacuum lines? I don't think CSK carries that stuff. I may try Merle's (local). Otherwise I might need to call Ford.
I broke all of them last night trying to get everything hooked up. They might as well be made of glass. I swear they break if you look at them the wrong way. One of the lines broke and then broke again when I flinched.
I'm reluctant to use rubber lines since they compress under vacuum and cause things to not switch on/off properly. But, I may run rubber as a temporary fix but I definitely gotta fine the plastic replacements.
toyman
1,944
54
79
Vernon BC
May 23, 2010
  • May 23, 2010
I would be surprised if actual vacuum line tubing (rubber) would collapse under 20 inHg. If you want a stiffer line consider small diameter fuel line with the woven fiber. An another alternative may be the use of plastic "drip" lines used in automated watering systems. The tubing is about the same diameter and in not expensive. Use the rubber vacuum line for couplers.
TrueBlue95GT
966
Connecticut
May 23, 2010
  • May 23, 2010
Just delete it all.
ProKiller
3,064
15
78
PA
May 23, 2010
  • May 23, 2010
all those lines go to the smog stuff. just remove them all. that is unless you have to have them for inspection
KamiKaziDK
555
Mesa, Az
May 23, 2010
  • May 23, 2010
Our emissions in Arizona is pretty strict....2nd behind Cali to be exact. Just buy some rubber and shove those tubes into it to connect them, that's all I've done.
HISSIN50
34
129
May 23, 2010
  • May 23, 2010
I've also spliced the breaks with rubber bits. It's lame but.......
Did you ask the counter guy for bulk plastic line?
Zero Signal
2,633
Tucson, AZ
May 23, 2010
  • May 23, 2010
I think I'll just hit up the Merle's and see if I can get some bulk line. The drip line idea is worth looking into if they don't have the automotive version.
desertcox05
379
south atlanta
May 23, 2010
  • May 23, 2010
As a temp fix I use heat shrink tubing.
It worked for a single break but I think you need total replacement
Vinnietbird
584
  • May 23, 2010
Our local Autozone carries rolls of that line,and all kinds of caps,"T"'s,and ends for them.
AC vacuum line in firewall
  • Bobburnett1954
  • Jul 1, 2024
1996 - 2004 SN95 Mustang -General/Talk- Jul 1, 2024
Mcmahst
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
