i have a choice to make an need your help :
i an currently running a 5.0 bored .030 over 306ci , trick flow heads an street heat intake , 76mm maf , 75mm t/b , 24lb injectors , e303 cam , 1.6 rockers , double roller timeing chain , under drive pulleys , sfi balancer an an anderson power pipe , according to trick flow i should be makeing 350hp 370lb ft tq
now here is the delema , i have a choice to make , an need your help to make it ,
1. a tremec tko600 conversion , ( stock 88 t-5 )
or
2. a complete areomotive fuel system
or
