P projectstallion New Member Mar 8, 2004 17 0 0 Mar 27, 2008 #1 Mar 27, 2008 #1 i have a 70 coupe with a stock 302 to advance the timing i turn the dist clockwise or counter clockwise?
rbohm Founding Member Apr 12, 2002 6,698 550 204 tucson,az Mar 27, 2008 #2 Mar 27, 2008 #2 you always turn the distributor in the opposite direction of its rotation to advance the ignition timing. in this case since distributor rotation is counter clockwise you turn the distributor clockwise.
B BornInAFord Member Apr 22, 2005 199 0 17 Bend, OR 97701 Mar 27, 2008 #3 Mar 27, 2008 #3 Correct, clockwise to advance
ashford Member Dec 19, 2003 485 0 16 fargo ND Mar 29, 2008 #4 Mar 29, 2008 #4 pull on the vac advance pod, this way you never mess up no matter what make or direction it turns
