Sub-Frame Connector Installation
titanio
Duncan
I just got a set of BBK bolt-in sub-frame connectors and went to put them on but cant seem to figure out where they should fit. To fit them on the rear sub-frame the cross-member interferes at the front, but when I move them so they clear the cross-member other brackets run interference at the rear. Anyone got any advice? Thanks in advance.
Are you sure you got the correct ones? Didn't BBK send any instructions?
I would contact BBK directly; they should be able to answer any questions. It's a little difficult to give any good advice without actually being able to see where they're interfering.
BTW - make sure you have them welded. They will do very little to help you if you only bolt them in.
I called BBK and their tech guy said that the 79-93 Ford Mustang Sub-Frame Connectors don't work on 4 cylinders. Good thing it said that in the catalogue...or website...or instructions. Thanks for your input though guys. Now, Can anyone recommend some sub-frame connectors that will fit a 4 cylinder?
All the chassis are the same so i think that guy was smoking something. Anything chassis related that fits on an 8 will fit on a 4. As will most suspension stuff. But if you want to send em back Go ahead. I have steeda's on my car and they Make a HUGE difference in how the car feels. I do agree with everyone though, DO NOT bolt them on, Weld only, usually muffler shops will do it for less then a bill.
Dr.
