Sub Frame Help
Making your own can be a PITA, IMO. If you make your own, I would use round tube steel. The torsional strength and rigidity of round compared to square or flat stock is like night and day.
Joe
Kenny Brown has nice ones. Maximum Motorsports is great. MAKE SURE THEY ARE WELD IN!! get the seat bracket braces as well. full length subframes are better, tubular is better.
I got custom subframes... Go from the front to the back (full length thru floor) I love mine. Also got Custom Battle Box also with the deal and tow strap bar installed. I'll take a video this winter and post it... When I jack up on any side of the subframe (no joke) 3 wheels come off the ground at the same time.. I could really tell a difference with mine and my 60ft went down. Custom is the only way to go.
I have MM full lengths, love em, tubular is awesome until you try to put a jack on them. If I were to do them again I would like tubular but my maximum motorsports ones are great and easy to install accept for those damn little flanges you have to weld all over them! lol Ohh yeah dont waste your time with shorties or bolt ins.
95Vert said:
when you say seat tie ins,what exactly do you mean?
Here's what a full lenght sub looks like : ---I---
You weld each of the long end. The little "bar" bolts to 2 bolts that are already under the car. Those are already holding the seat. Look at the pic. I "squared" the "seat bracket" .
The seat brackets are crossbars that connect to your seat bolts or something like that. They run perpendicular to the subframe connectors. They are supposed to help with lateral movement. All I know for sure is that after I got mine welded in, it was a whole new car. Almost NO body roll at all. Definitely worth it.
Mavrick, get full length weld-ins with the seat brackets. Either Maximum Motorsports, or see if anybody can custom make them. I had mine custom made and they are SWEEEET!
95Vert said:
thanx for the replies, just one final question, and i don't mean to hijack, tubular or square?
I think this has been answered, tubular is supposed to be stronger, but square I think is easier to find and install. Plus I think it's cheaper. Either way, as long as it's full-length and weld-in, omg you can't go wrong.
