Subframe Advice Needed
  • Thread starter Thread starter BeerElf
  • Start date Start date Dec 28, 2004
BeerElf
85
Hillsboro, OR
Dec 28, 2004
  • Dec 28, 2004
I'm looking for a set of Subframe connectors. Any advice or suggestions would be appreciated.
Here are the three that I'm considering. Let me know if you have any good/bad experiences with any of these.
Competition Engineering #C3045 weld in (right now these are at the top of my list because they appear to give the best ground clearance since the weld into the subframes instead of on top of them)
Steeda #555-5245 Full Length Sub-Frame Connectors (these are second on my list since they appear to be the strongest of the three)
HPM Crossbar Subframe Connectors from 5.0 Resto #HPM-5400-AZ (and these are on the list mostly because they are cheap, but I'll probably not buy these because they of that)
Thanks!
Craig
04sleeper
2,674
14
89
Dallas, TX
Dec 28, 2004
  • Dec 28, 2004
You will find that all 3 of those will work about the same. The thickness of the steel being the key.
I have ones similar to the ones on the bottom but they are zinc coated like Steeda's. They work fine.
giddyup306
3,041
Dec 28, 2004
  • Dec 28, 2004
I bought a set of HPM. Mostly because they are cheap and there store is locate in Omaha (30 mins from where I live). Whatever you decide make sure they are WELD IN connectors. I wouldn't go with CE b/c they don't have the flanges to bolt to the bottom of the seat bracket. Steeda has them but you will have to weld them = more work.
BeerElf
85
Hillsboro, OR
Dec 28, 2004
  • Dec 28, 2004
Thanks! I don't mind the extra welding.
Anyone else?
9
'90DarkBlueLX
26
Portland, OR
Dec 29, 2004
  • Dec 29, 2004
I have the HPM, so do a couple of my friends. They work great and support the seat well. Do be sure to use the bolts through the rear seat mount and bolt them to the sub-frame connectors. It helps keep the floor from flexing and the seat from moving around.
Also I second or third the weld in option. The bolt in are just a waste of time.
Good luck.
Remember that the frame rails that you are welding to are much thinner than the subframe connector so go easy on them. They burn through very easy if you go for too fast.
giddyup306
3,041
Dec 29, 2004
  • Dec 29, 2004
Anyone else?
I mean the HPM already have them on ready to go. I should have been more clear.
R
ratrapp
510
buena vista,va
Dec 29, 2004
  • Dec 29, 2004
i've got the crossbar style also.i got mine from blueoval industries for $40.on an average street car they serve the purpose as long as they're welded in.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 29, 2004
  • Dec 29, 2004
I would get the Steeda sub's!
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Dec 29, 2004
  • Dec 29, 2004
I'd have to suggest either Steeda, Maximum Motorsports or Griggs Racing. I did some research on'em a while back but decided to just stick with mine (FMS tubular).
boomr
51
WA
Dec 29, 2004
#10
  • Dec 29, 2004
  • #10
I installed the Maximum Motorsports full length, mucho difference afterwards
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
