  • Special Production
Roush Subframe Connectors for 04 Vert????
  • Thread starter Thread starter sy1172
  • Start date Start date Oct 9, 2005
sy1172
175
  • Oct 9, 2005
I want to tighten up my 04 281SC vert and am considering subframe connectors. Doesn't Ford or Saleen install a simple set? Appears this way.
Any recommendations of suggestions? What is the best brand?
Thanks,
2000xp8
SN Certified Technician
Aug 8, 2003
8,016
1,613
194
NJ
Oct 9, 2005
  • Oct 9, 2005
I've been under a couple hundred different mustangs, considering my friend owns a mustang only shop.
I look at everyones subs.
Only 2 sets i would buy.
First would be the set from Global West, second would be the full lenght set from Maximum motorsports.
With that said, i had always thought that subframe connections were part of the saleen suspension package.
marcus95
2,133
California
Oct 9, 2005
  • Oct 9, 2005
Having experience with both of XP8's choices I prefer the Global West singles with seat supports. If you want to go extreme you can get the GW tri ladders. HeadPaneer has pics somewhere posted. Do a search.
Anyway, back in the day you could have Saleen install non full length bolt on sub frames on your Fox. I have them. Otherwise, Saleen's do not come with them.
Tommy98016
89
New York
Oct 9, 2005
  • Oct 9, 2005
I have a 03 vert that I am going to put on Kenny Brown Extreme Matrix System Zinc 94-04 Mustang & Cobra (KBP29550). The KB's Exteme Matrix Subframe system comes complete with 2 subframe connectors, 2 matrix braces, and 2 jacking rails.
Head Paneer
1,823
Surf City, CA
Oct 10, 2005
  • Oct 10, 2005
Well I think you already made your decision by now but here is what the Tri-ladders look like installed. I highly recommend them. This is the passenger side, btw.
I still need to get a better pic of these things.
ag lightning
134
  • Oct 10, 2005
Are those welded in??
*If you're going to do subs, you've got to get them welded in! Don't fall for the simple "bolt-on" ones.
Head Paneer
1,823
Surf City, CA
Oct 10, 2005
  • Oct 10, 2005
Yes, very welded. The outside square tube is welded the full length along the pinch seam of the body. The large inner round tube is welded in several places as well. The seats bolt to one of the cross braces.
I should also note that there are no ground clearance issues. They have never hit on any road obstruction.
ag lightning
134
  • Oct 10, 2005
Those are nice. Someone did some great install work. Very clean
F
fallstar01
54
  • Oct 13, 2005
I've heard that it's better to stich the welds for some reason instead of welding the full length.
Some people have taken the kenny brown extreme matrix cross braces and jacking rails and connected them to MM full length subframes.
Also, I've heard of "through the floor" subframe connectors as well but I don't know much about them.
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
