Looking for some recommendations on subframe connectors for my convertible. I know that TCP made some that had a center connector in there that was a bolt-in. The side/main connectors were weld-in, the centers were bolt-in. Should I just go with these or does anyone else have a recommendation? My goals are:
1. Must have center connector
2. Rigidity, non-flexy-flyer
3. Ground clearance
I'm also not sure the TCP unit is currently made. I prefer to order from Mustang Depot for the TCP, but they've been out of stock for a while . . .
write-up on my r&p/coilover coming sometime next week.
3. Ground clearance
whenever you want and then adjust it up to a height where you can clear speed bumps. I'm still not convinced about the handling of a car with air bags, I'd have to try a car with them on it to be really sure. I'm actually considering it for my rear, though - coilovers in front. That might solve your problem to have bags just in the rear. You could adjust rake with the push of a button if you get the more expensive kit. Low-ry-duh
don't hit no bump now da da da da da da da, da da da dum dum.
