Subframe install?
Bosko5.0 said:
Does the cars suspension need to be under load when their welded in?
Yes the car needs to be sitting like it would be on the ground. That way the subframes don't get put on while the car is twisted.
Bosko5.0 said:
How much should I expect to pay to have them installed?(just so i dont get ripped off:mad: )
At a mustang shop around here it's $300 to buy their subframes and have them installed or if you bring your own (I bought some full-length powdercoated MMs) the install was around $150.
Wes
Most good shops will install them on a muffler shop style life (raising the car from its tires). It IS important to have the car loaded on its suspension.
Install prices, I'd expect anywhere from $70 if you get a deal from a friend to prolly about $150 otherwise.
When I had mine installed they tack welded them in place crawling under the car and then lifted it by the frame to finish everything off. It's a well known Mustang shop in Houston so I figure they know what they are doing. I was charged $120 and it took the guy almost 2 hours.
