SOLD 1988 Notch for sale
GT80
31
Greenville, SC
I bought this car in 2014 as a roller and put the drivetrain from a 1990 hatch in it. I did the 5-lug conversion and the rear disc brake conversion as well as GT seats. Welded subframe connectors and SVE suspension all around. I can provide more pics and I have a lift in my garage so I can provide underside pics as well upon request. Asking $13k
I thought I had lost this list but found it today. Below is a list of parts I bought and installed put on since I bought the car. None have more than 1000 miles on them since I don't think I've driven the car more than 1000 miles in the past 10 years.
Fuel Tank
Ignition Switch (LRS-11572A)
Fuel Pump
Fuel Fill Grommet (LRS-9072A)
Rear Spring Isolators (Energy Susp ENS-4-6101G)
Rear Control Arm Bolts (M12x90 & M12x110 Grade 10.8)
Motor Mounts (LRS-6038PR)
Motor Mount Hardware (LRS-6038HDW)
Trans Rebuild Parts (thegearbox.org T5 WC Master Kit)
Speedo Drive Gear (7T from FoxMustangResto)
Door Handles (LRS-22404K)
Flywheel Resurfacing (NAPA Mauldin)
Throttle Body/EGR Gaskets (BBK #1572)
Exhaust Gaskets (M9448B302)
Oil Pan Gasket (LRS-6710A)
Pilot Bearing (LRS-7600A)
Rear Main Seal (LRS-6701A)
Upper Intake Gasket (LRS-9486A)
Clutch (FR M-7560-A302N)
Performance Parts Inc Clutch cable (Ford OEM)
Water Pump (M-8501-C50)
Mass Air Conversion Kit (CH-8611-F)
Brake Proportioning Valve (M-2328-C)
3-2 Brake Line Adapter (MMBAK-3)
Rear Parking Brake Cables (2) (LRS-2635D)
Front Parking Brake Cable (M-2810-A)
Headlights (LRS-13007E-KIT)
94 GT Master Cylinder & Brake Booster (eBay)
Hood Struts (LRS-16826C)
Clutch Cable Firewall Adjuster (SVE-7553-H)
95 GT Rear Disc Brake Parts (eBay)
Rear Caliper Soft Lines (DHB-380371 & 72)
Rear End Bearing & Seal Kit (LRS-4210A)
Differential Spider Gears (Ford 2L1Z-4215-EA)
Differential Pinion Shaft (Ford E9AZ-4211-A)
Differential Clutch (FMS-M-4700-C)
Timing Chain Set (CCA-2138)
Timing Cover Gasket (FEL-TCS45449)
Harmonic Balancer (FMS-M-6316-M50)
Oil Pump (SLP-224-41118)
Brake Line Adapters (Balkamp 641-3306)
Valve Cover Gaskets (FMS-M-6584-A50)
Clutch Fork (SUM-700105)
Clutch Fork Ball Stud (MCL-16910)
Spark Plugs (ASF42C)
Axle Bearings (SKF 13992)
Transmission Mount (LRS-6068A)
Steering Rack (Cardone 22-207)
Transmission Tunnel Hump (FP20-79TC)
Fuel Injection Hose & Clamps (5/16" SAE30R9)
Tie Rod End Boots (Energy Susp 9.13101R)
Steering Rag Joint Disc (Dorman 31000)
Coolant Bypass Hose (AM 52953 / Motorcraft KM640)
PCV Filter (E6ZZ-6A631-B / FA1068)
PCV Grommet (F7CZ-6A892-AA)
Window Guides and Door Lock Actuators
Tires (Riken Raptor 245/45-ZR17)
Weatherstripping Kit (Daniel Carpenter)
EGR Spacer Gasket (FEL 70262)
Throttle Body Gasket (FEL 72543)
Oil Fill Cap (F3AZ-6766-B)
Speedo Cable (LRS-17260B)
Speedometer Gear (7T drive gear)
HVAC Control Panel
Upper Condenser Brackets (Corral.net)
Wiper Motor (40-297)
A/C Compressor & Discharge Line (Corral.net)
A/C Condenser (Spectra 7-4453)
A/C Liquid Line (Everco 3512)
A/C Accumulator (Everco 3617)
Rear Control Arms (MM-MMRLCA1) (LRS-5500CA-K)
Coilover Suspension (SVE-47375KA)
Subframe Connectors (MM-MMFL5B)
Prothane front bushings and sway bar end links (PT-19417PL & PT-6205BL)
Plus I have some spares like new LMR door panels, Ford racing shorty headers, stock upholstery for the rear seats to match the front, new carpet (I prefer the old). Misc parts. All comes with it. Just never installed.
I got it on the lift today. Went ahead and changed the oil while I had it up. I took pictures of everything I could think of. I'll probably keep it lifted for another few days just in case someone wants to see something in particular.
More pics
More Pics
More Pics
More Pics
Pm me have some questions
