  • 1994 - 1995 Specific Tech
Suc-ky Luck!!
  • Thread starter Thread starter 94GTLaserRC
  • Start date Start date May 11, 2004
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
May 11, 2004
  • May 11, 2004
Water neck Leak:
Well, pulled off the chrome water neck tonight (outside in the dark) and cleaned off the lower intake outlet.
I bought an OEM water neck from D.A. It looked almost exactly the same as the chromer, but obviously, cast metal. I took a straight edge to the bottom and I could see how the cast one looked more perfectly flat. So I thought "that's the reason it's leaking."
I prepped the intake outlet, put the Tstat in with some BLACK RTV, let it sit...Then put a thin film of RTV on, then the gasket, the waited a few minutes...then put another film of RTV on...let dry for a few minutes...THEN:
When I went to put the bolts through to screw in the intake, the holes would NOT line up REASON, the piece on the left of the bypass hose was hitting up against the alt bracket (since the alt is moved from the blower)
SO NOW...Im sitting here with a prepped water neck with RTV hardening on it, and NOT able to get it on now so it can dry over night. Why are the most minor fixes the most PITA!!!
ONLY BRIGHT SIDE: I decided not to bother polishing it b/c I didnt have the patience....CAN YOU IMAGINE IF I HAD POLISHED THE WHOLE THING, THEN FOUND IT DIDNT FIT???
Oh well...Im F....g going to bed now
RC
9
95StocK50
398
Idaho
May 11, 2004
  • May 11, 2004
damn man that sucks the bad part is I have had days just like this...its like my car is getting back at me for rodding on it...lol
nathan
Badlilstang
1,606
Spring , Texas
May 11, 2004
  • May 11, 2004
Do you have a NAPA? or a machine shop near you? Id take that chrome one and get it surfaced.. it has to be something with that surface thats isnt flat like you said you saw with a strait edge. I did mine like 5 times and gave up on it.. but I didnt think about surfacing it till I had the stocker back on. I just changed to a robertshaw thermostat bout a month ago and again the stocker went on fine with no leaks.. So im guessing my chrome housing wasnt flat either. Good luck on your next attempt.
Badlilstang
1,606
Spring , Texas
May 11, 2004
  • May 11, 2004
Not that you would probably want to pay these prices but these housings look pretty sweet.
http://www.martelbrothers.com/customer/product.php?productid=CSI9110&cat=1355&page=1
I didnt notice a hole for a sending unit tho.
Y
yellow1995Cobra
2,959
Massachusetts
May 11, 2004
  • May 11, 2004
like i said in ur previous thread its the typhoon intake man. When i had my s trim, the bracket would hit it too, you need to grind it down a bit.
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
May 11, 2004
  • May 11, 2004
RC, still want my old stock t-stat housing? Still got it if ya need it. Did you try to put it on the way I did mine? I didnt use a gasket at all... Stuck the t-stat on the housing, put RTV aroundthe gasket and housing to hold it in place a little, then put a pretty thick bead of RTV around the entire perimeter, stick the bolts through it and start them into the intake, then push the housing on all the way, then tighten up the bolts while still holding the housing in place... If you got enough RTV on there it should fill in the low spots on your housing and shouldnt leak... Thats what I did and it worked for me! Let me know if you still want my old housing and I'll get it sent out tomorrow if I hear back in time. Overnight it for ya too
SuperStang83
1,693
Boyertown, Pa
May 11, 2004
  • May 11, 2004
That does suck when the smallest things can be a hassle, or when you start to fix something and realize that it was hiding a much bigger problem!
Jakob
94GTLaserRC
11,178
May 12, 2004
  • May 12, 2004
Zach..Ill give it one more try today...Then Ill let you know tonight.
Yellow: Even though the after market one is not chromed, it does seem to be very strong and true..Last night when it didnt fit, I already had the RTV on it semi wet, so I couldnt do much with it..Today, Ill remove the dried RTV and see if I can grind down the one edge. IF that fits, it seems tight enough to stop the leaking...Keep in mind it wasnt a major leak, but for cooling NO LEAK = Minimum acceptable thing.
RC
94GTLaserRC
11,178
May 12, 2004
  • May 12, 2004
UPDATE:
Went to Autozone...Their water neck is a different brand, but the SAME item.."CHINA 884" Joe said he used this one on his neighbor's car and it is STRONG heavy steel..You can torque that baby down tight.
Anyway, since it was the same one, I decided my only options were to
-go back to stock without a screw top
-RETRY the chromer with more RTV
-try to grind down some of the areas of the new steel one.
After cleaning the black RTV from last night really good, I went with the 3rd choice. Luckily, I have bench grinder and Dremel. I rounded off the area to the left of the bypass nipple, then sanded. I got the bolts to line up
Then I thought "Id better dry fit the ENTIRE hookup including all the hoses....GOOD THING I DID..
1. The bypass nipple was too close to the alt bracket to slip the bypass hose on...so I had to grind the outer fatter edge a bit.
2. The Top outlet for the upper hose was too big for my hose to slip on (because I have that chrome sleeve, with a double rubber couple inside)>....So I had to sand the diameter down a couple of mm's on an area about 1" down the outlet.
Finally I got everything to dry fit and assembled it just 1/2 hour ago...Im waiting for it to dry, And I dont need to the car, so Ill try to refill it tomorrow at 7PM after work.
Im skeptical b/c of all the problems so far, but it "does seem" to feel tighter around the bottom, and since Joe said I could tq it a lot, I used a ratchet and 1/4" hex head to tighten it really good.
I must say that when I cleaned the RTV off the housing (AGAIN), the black did seem harder to get off than the red...I guess that means it bonds better
Wish me luck..
Thanks
RC
Badlilstang
1,606
Spring , Texas
May 12, 2004
#10
  • May 12, 2004
  • #10
Good luck man.
1105
May 3, 2003
3,841
Daytona Bch, FL
May 12, 2004
#11
  • May 12, 2004
  • #11
Badlilstang said:
Good luck man.
Hes gonna need it. Anyone wanna make a bet on if it seals properly or not? I have faith in RC so I say it'll work this time
94GTLaserRC
11,178
May 12, 2004
#12
  • May 12, 2004
  • #12
I have faith in ME too...it's all those dang parts I dont have faith in.
I will say tho that the black RTV seems to be firmer and stronger than the red stuff.
RC
Badlilstang
1,606
Spring , Texas
May 12, 2004
#13
  • May 12, 2004
  • #13
RC
Next time use JB Weld ... that will seal it lol. I agree with the whole parts thing tho... seems like a lot of companys dont give a crap about quality control anymore.
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
