I will, make sure all of the associated linkage is clean and without any binding. Also, you do know the fast idle cam comes into play on initial cold start.
As a refresher, on a typical cold start, when you set the accelerator, the choke closes leaving a slight opening of about an 1/8". At the same time, the choke arm steps a cam on the idle adjustment side, that, bumps the idle to about 1200-1500 RPMs. As you warm the engine the the electric choke is retracting (2-3 minutes) the choke plate, at the same time, it's backing off the "fast idle" cam lowering your idle. During normal operation that choke plate should be in verticle position, but then, I think this was mentioned, as well.
When reviewing this issue, it's a good time to set your carb'ss idle mix using a vac gauge, check your engine's idle vac, and verify the timing is within your engine's specs.
Happy Motoring!
