Ok I ordered a set of summit brand piston rings and the top gap is .028!?!?!?! I know there's nothing wrong with the bore it's a fresh .060 overbore on a 351w block. I had a set of speed pro cast iron rings that I messed up a few oil control rings because I was using a old adj. ring compressor(got a tapered one now). I put one of the old speed pro cast rings in and measured a .016 on the top ring gap so I know nothings wrong with cylinder. After messing up a few of the speed pro oil rings I decided to just froget it and get a set of summit moly rings pn#sum-133-m139-60.
I used a piston to push the top ring down evenly in the bore about 3-4 inches down. I tried a .016 feeler tab(brand new feeler gauge from oreilly's) and it was like throwin a pencil down a open hallway. I went up from there and the guage didn't get tight until I put a .028 feeler tab in!!!!!!! What the hell man that's way too friggin loose!!!!! I should have a .016 on top(.004xbore) and a .020(.005xbore) on the second ring. And my second rings are measuring a little tighter than .020 more like a .019.
I contacted summit through livechat and they said it must've been a packaging error at the warehouse. The second rings were pretty uniform and I have a ring filer so I could've opened them up a little bit to be .020 exactly. But DAMN I can't add metal to the top rings that are measuring .028!!! When you stack the top rings together you can see that they don't even match each other and have completely different gaps!!! The guy said he'd have UPS come pick the old ones up and that a new set will ship out tomorrow and be to me between tue-wed. I REALLY wanted to put my motor together this weekend but now I have to wait till next weekend because of this and I'm pissed
. And from the looks of it how do I know the new ones will be any better??? I've done a lot of buisness with summit racing that's why I wanted to give their rings a chance. If the new set comes in and is screwed up like these I don't know if I'll be able to ever order from them again. I'll find myself becoming a jegs fan real quick and in a hurry!
. The only thing is there're moly coating isn't as bright and lusterous as the hastings rings but you know what screw it their just gonna have to do. I called summit and there're gonna give me a refund(yes I was polite and didn't chew the guy out) but I'm gonna take a pic later tonight of the two rings so you can see what I'm talking about. The second rings and oil rings between the two sets are a match but the hastings top rings are clearly smaller overall then the speed pros.
ee:
