Stick with the stewarts. Stay away from Milidon. They may flow well at high rpm but not enough at idle which is when you need it the most. Summit also sells stewarts. Another good option is the edelbrock water pump but they can be a bit expensive. Just don't go cheap on a waterpump. Cooling is not something that you can afford to have something break.
Kevin
